totally unhappy with the pressure treated pine, I recut the arms out of ipe,(the only 3/4 I had left) and finished all the fine tuning and tweeking.
Ofcourse, my day wouldnt have been complete without the last cut of the chair, the last tenon shaping, I lost my grip and the board moved, choped a bit too much off the end, so the tenon was thin.
It shifts a bit too much, the back slat on the right, so I tried some unfancy woodwork, now its worse.
Im going to build it up from inside the mortise on the bottom, a drop of play is fine for the back slats.Id just rather not see any space on the top of the slat.
I have to rout it all over, again, no 1/8th roundover, so Ill have to go with my 1/4 inch.This will remain a no buy anything build, using what I have.
I dug threw the spiders and sawdust and found some old stains to give the PT a bit of flavor.
The only light shade I have is golden pecan by minwax, everything else is very dark.(so golden pecan it is, I believe that was the shade, Id have to check again)I can use one of the red stains, red chestnut, sedonia red, but I thought a light shade would contrast the dark walnut coloring of the ipe nicely.
Any thoughts, I will take advice on anything.
(the rockers arent attached in the pic, dry fitting over and over again gets tiresome)
