Results 1 to 6 of 6
Thread: brass on the planes
    17,472
    brass on the planes
    ok whats the best way to clean the brass on the old planes? the adjusting wheels and the screw tops? also after they are cleaned up, what over coat is best ? spray then with some laquer or is there a better way to keep them lookin good?
    Michigan
    2,436
    Years ago (1972) I joined what is known as ROTC...Reserve Officers something or other..... we used Brasso to clean our shiny brass buttons and belt buckles for inspection......does a great job cleaning
    Catalunya
    4,632
    No matter what I've used before to clean brass, it always ends becoming dull.
    Lacquering brass parts delays a bit the process, but sometimes starts to peel off and the result is even worse because the piece has shiny spots and dull ones.
    Eventually I just gave up and don't even bother, specially if we are talking about tools. I think that the patina due to use gives tools and many things certain character
    Best regards,
    Toni
    17,472
    see toni that the differnce you use your tools i just look at mine
    thask for the brasso tip ashman
    Catalunya
    4,632
    If I had to judge for your last "box" I'm pretty sure that it is the opposite way, unless you have so many different machines that you do not need hand tools at all
    Best regards,
    Toni
    A buffing wheel and buffing compounds applies a light layer of way to the surface of the brass REDUCING tarnish, but of course time will kill it eventually. I cannot remember the color of the rouge to use...black perhaps? Vaughn can tell you better as I only use green and white but its on stainless steel and not brass.
  1. Making Moulding Planes - Wooden Planes
    By Tom Becnel in forum Handtool Project Showcase
    Last Post: 05-15-2012, 08:35 PM
  2. brass planes
    By Frank Fusco in forum Neander Tool Questions and Show & Tell
    Last Post: 07-23-2009, 04:07 PM
  3. Brass 7mm
    Last Post: 05-16-2009, 02:51 AM
  4. Gluing brass to brass
    By Larry Browning in forum General Woodworking Q&A
    Last Post: 12-07-2008, 12:33 AM
  5. Brass
    By Wes Bischel in forum Off Topic Discussion
    Last Post: 09-01-2008, 12:19 AM
