Results 1 to 5 of 5
Thread: Delta belt problem
    Geelong Australia
    3
    Angry Delta belt problem
    A couple of years ago I brought a secondhand Delta 36-600 table saw. I had to replace the small timing belt between the motor and the blade arbor when I got it. I have just lost the drive again and found the belt shreaded. I have not used the saw on a daily basis and felt this was not a very long life. As the saw reaches full speed in about half a second, there is a lot of load on this small belt.
    My question is, should the saw accelerate at this speed, and is this the life I should expect from the belt.
    Dallas:
    17,475
    not up tp speed on your saw but i can suggest with great sucess the RED link belts they are good belt for tsaw elimante vibration and can be made to fit anything,,
    lutefisk capitol, USA
    485
    Second the link belts. Made the vibration go away and has been on the saw for 10 years. I have an older blue Jet contractor saw.
    Dale
    dallas, a link belt will not fit on your saw, check pulley alignment when installing your next belt and keep your eyes open for a true contractors saw if you like the size and portability of the one you`re using? a true contractors saw will have a motor hanging behind the saw on a hinge and the weight of the motor will tension the belt.
    9,077
    I'm with Tod. Alignment is the only thing I can think of that might shred that belt.
  1. Delta model 31-396 edge sander ( belt troubles..)
    By larry merlau in forum New Tools
    Last Post: 01-10-2014, 05:57 PM
  2. Problem with my Delta 40-560 scroll saw.
    By Tom Baugues in forum Old Iron
    Last Post: 02-14-2012, 01:57 AM
  3. Delta starting problem
    By Dallas Polley in forum General Woodworking Q&A
    Last Post: 12-08-2009, 02:00 AM
  4. How change belt Delta 46-140
    By Jim C Bradley in forum Turning Tool Questions and Show & Tell
    Last Post: 07-26-2009, 07:37 PM
  5. Delta Unisaw problem
    By Rick Levine in forum General Woodworking Q&A
    Last Post: 01-29-2008, 11:56 PM
