Results 1 to 10 of 12
Thread: Some Pens
    13,356
    Some Pens
    Well, I'm not much of a turner, but I do like to make pens from time to time.
    Here are a few pens I've recently turned. A couple have been sold, Most of them are going out as gifts.
    The Rosewood with the cherry inlay is actually one of the better 'celtic crosses' I've done. I finally got a self centering pen vise. Making sure the blank was perfectly square and that the inlay thickness matched the kerf thickness really helped.
    RoseWood with Cherry Inlay
    Rosewood and Bloodwood Inlay
    Spalted Maple
    Walnut Burl
    Purple Heart Americana Bullet
    Aug 2008
    Reno, Nv
    3,632
    Trade ya all my salt box tricks if you show me how to do inlays like that
    13,356
    It's an easy enough concept. I stole it from a pen turning website.
    The concept is that you take the blank, saw it at an angle, glue in a strip of wood to replace the kerf you removed. Rotate the blank and do it again. You can rotate the blank 90 degrees each time, but I think doing a 180 and then doing the other sides works better, visually. (Clear as mud?)
    There are 4 very important keys I've found to get these to look right.
    1) The blank must be exactly square
    2) The inlay must be exactly the same thickness as the kerf, maybe a few thou less, depending on how sloppy you glue it up.
    3) When gluing, pay more attention to the lining up of the inlay than the sides of the blank
    4) The hole must be drilled exactly in the center of the blank.
    I'm still working on getting all of these to work out correctly. If you don't you get lopsided loops. I've found some people like these, but I know they aren't right, so I don't give those away. I either don't assemble the pen, or I take it apart and throw the barrels away. It's one reason I have purchased way more cigar pen brass tubes than kits
    I also find that you need to use a bit steeper angle than 45 for things to look good. I typically go for about a 60 degree angle, it gives it more of a 'swoop'.
    It's fun. But I do find that I tend to get my fingers covered in medium thick CA glue putting these together....
    30,002
    Great pens, Brent. The Rosewood/cherry one is especially nice.
    Jim, here's a great video on making celtic knot pens. This one (made as a homework project by an 11 year old kid) uses a slightly different method for adding the lines...he doesn't saw all the way through the blank. The kid's a pretty good videographer, too.
    http://www.ncwoodworker.net/pp/showp...91&ppuser=2069
    13,356
    That kid gives me hope for the next generation!
    What a great video!
    I'm definitely stealing that technique.
    It might keep my fingers from getting so coated in CA glue....
    Goodland, Kansas
    4,834
    Great looking pens. I really like the rosewood/cherry and the spalted maple.
    Bernie W.
    Brent, very nice pens indeed!
    Vaughn, that is one great video, the kid has talent
    Oct 2007
    Harvey, Michigan
    687
    Brent - really nice work on all your pens! Really like the spalted maple!
    Steve
    May 2008
    Xenia, Ohio
    193
    Love the first one right off the bat! Really nice set of pens.
    Aug 2008
    Reno, Nv
    3,632
    I just watched that video. Dinner crossed my mind, but humble pie is waiting for me in the shop.
  1. New Pens
    By Ron Hossack in forum Lathe Project Showcase
    Last Post: 09-09-2011, 12:31 PM
  2. A few Pens
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 05-19-2011, 10:01 AM
  3. Just pens
    Last Post: 05-04-2011, 03:11 PM
  4. Two Pens
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 11-11-2009, 01:53 PM
  5. More pens!
    Last Post: 11-05-2008, 10:28 PM
