Results 1 to 10 of 24
Thread: First Try At Celtic Knots
    After seeing the video that Vaughn posted >> HERE << of a very talented young man, AlexL aged eleven.
    I was watching his well done demo of how to make a Celtic Knot pen and I thought, "I can do that"
    The tip that I gained the most from, was when cutting for the inlay piece, to not cut all the way through, this certainly has made things MUCH easier.
    OK, I started out with a simple maple blank, a little under 3/4"
ID:	24883 Click image for larger version.
    I also cut some Purple Heart, to use as the inlay.
    I did not use the bandsaw to make the cut, I used my SCMS to make the cut. I do not know if any other saws have this function, I'd have to think they would. I can set the depth of cut for the saw, so I put a piece of plywood on the saw, to give me a flat base, and another piece to bring the blank to be cut away from the fence a bit, then I set the saw to 45 degrees, and set the depth of cut, to just not cut through the blank all the way. Since I'm a beginner on this stuff, I also numbered each side of blank, so I could keep track.
    Ready to make the first cut
    First cut made!
    I then glued the inlay in place, using medium CA glue, and then pared off the extra wood to make the blank square again.
ID:	24889 Click image for larger version.
ID:	24890 Click image for larger version.
    Ready to make the 2nd cut, 2nd cut made, 2nd inlay glued in place..........
ID:	24892 Click image for larger version.
    Ready to cut the 3rd cut, and then the 4th cut.
    I also did a piece with Quince inlay, here it is ready to turn.
ID:	24895 Click image for larger version.
    Here is the Purple Heart inlay piece, I think I did not bad for a first try.
ID:	24897 Click image for larger version.
    Here is the Quince inlay piece, again, I really like this, it is almost magical
    Now these two pieces were just for fun, for practice and to see if this way of making the cuts etc. would work, and I think I like this
    I can certainly see making some pens from this, and I can see doing this on other items, lets say the toothpick holders or some other items.
    30,008
    Very cool, Stu. My brother-in-law is into things like Celtic knots and such. (He's a Viking re-enactor.) I might have to make him a pen or something similar for Christmas.
    Alexandria, Virginia
    1,071
    This technique would allow for beautiful rolling pins, tool handles, etc. Thanks.
    Frank, for something like tool handles, and rolling pins, I'd use a PVA gule, titebond etc, NOT CA glue, I used the CA glue, as it is fast, but for tool handles, etc, the PVA glue would be a LOT stronger.
    Hey, Screwdrivers, or the Pig Tailed Flipper handles, those would look GREAT with this design
    Charlotte, NC
    1,487
    Alex is a pretty cool kid. I've been watching his since he started, which, if I remember correctly, is less than a year!!! When you go over to NCWW check out his gallery!
    Never take life seriously. Nobody gets out alive anyway
    Mason Michigan
    455
    Thanks again for the tip, Stu!
    You are always a big help!
    "Small Change got rained on with his own 38"
    Tom Waits
    May 2008
    Xenia, Ohio
    193
    Great job on the knot! Now as for Alex... Wow! But can he do that same thing in my shop with my collection of tools.
    Goodland, Kansas
    4,834
    Great job Stu. That is well done.
    Bernie W.
    1,071
    Thank you Stuart! I also agree and any round "handle" would benefit!
  1. It's, shocking seeing knots...
    Last Post: 08-20-2014, 10:49 PM
  2. no knots? or ok knots
    Last Post: 12-27-2013, 10:39 PM
  3. Spoon with a twist and some knots
    By Ryan Mooney in forum Handtool Project Showcase
    Last Post: 02-24-2013, 04:27 AM
  4. 1 pen, 2 knots
    Last Post: 08-29-2009, 01:56 AM
  5. 2 Knots = 1 Pen
    Last Post: 05-14-2009, 01:14 PM
