Results 1 to 6 of 6
Thread: Small Shop Upgrade
    CNY - Williamstown
    42
    Small Shop Upgrade
    So, its getting closer to snowfall and colder temps so I thought it was time to make some improvements to the 2 doors to my shop. First and foremost was to increase security, second to ease access and third to help keep in some heat.
    My side door was an old trailer door with duct tape to cover the broken glass.
    My front door was a 32 inch solid core door. My first move was to move the front door to the side.
    I had to increase the rough opening to accept a 32inch door.
    and finally installed the door
    So now with the front door installed as the new side door I have a need for a new front door. I wanted to insure that the new front door would be large enough to get out any project I may build in the shop. This is to ensure I no longer have to take the door off to get out projects, DAMHIKT (x2). So I opted to build a 42inch insulated door. It would be made up of 2by material skinned on both sides with OSB and include a window.
    Door frame:
    assembled using pocket screws and went really fast.
    I framed up for the window:
    Then I installed the first skin:
    when trimming this skin is when I ran into my router bit problems.
    I didn't get pics of the insulation but it is stuffed with 1.5 inches of insulation board. Then the second skin went on and trimmed.
    I had to increase the door opening and then installed the door.
    And here is the homemade door installed and operational:
    and a close up of the window, which still needs to be trimmed out to keep it in place:
    Total cost was just the router repair kit to finish the door, everything else was recovered materials I had in stock. If I need to remove this door to get a project out I really messed something up. It took a couple weeks to get this done but is a great upgrade. New lock sets will be installed when I become gainfully employed again, but it's still a great upgrade so far.
    More upgrades to come.
    12,258
    Hi Ralph
    Well done on the upgrade. I am also extremely humbled by your post. It has made me realize and appreciate just how fortunate I am to be able to have built my "dream shop" . Wish you the best of luck in your search for employement. Wish I was able to help.
    11,833
    Good project, well done.
    Field, Ontario, Canada
    113
    Good job , nothin more satisfying than reclaiming old boards from the junk pile
    May it keep you warm in the months ahead
    Anything that can go wrong will go wrong, so keep your hands away and watch out!
    The shop is a constant flow of adjustments and improvements . . . and I'm OK with that. Looking good!
    Odessa, Tx
    1,813
    Good job, Ralph. Glad to see it all worked out for you and you "Got 'Er Done". My best wishes to you also on your Job Search.
  1. Shop wiring upgrade
    By Ken Cook in forum Carpentry and Construction
    Last Post: 02-23-2012, 05:43 AM
  2. Shop upgrade
    By Steve Southwood in forum Shop Tours
    Last Post: 06-11-2010, 10:20 AM
  3. Shop Upgrade - New Door
    By Bill Satko in forum Shop Tours
    Last Post: 11-25-2009, 04:49 AM
  4. My small shop
    By Bob Gibson in forum Shop Tours
    Last Post: 08-18-2009, 11:40 AM
  5. Small upgrade to shop...
    By Bartee Lamar in forum Shop Tours
    Last Post: 06-08-2009, 01:05 AM
