Results 1 to 4 of 4
Thread: Sanding tip for Turners
    Zushi, Japan
    739
    If you like me then you probably have a ROS. When I finish using the disk for flatwork I never throw them away though - I toss them in my used sand paper bag because there is always a little more scratch to be had from them. I use the old ROS disks two ways;
    1. I cut out the center and use it for power sanding
    2. I fold the outer edge and use it for spindle sanding, etc.
    Of course in the first case they work excellent but also in the second case they are great because the clothed side protects against overheating the digits.
    Central Illinois
    936
    Good tip, Alex.
    Bruce
    alex, all my old abrasives head toward the lathe....widebelt sander belts seem to last forever doing spinny stuff.....good tip!
    15,815
    Yep, that is a good one, Alex passed that one on to me a while back, thanks for jogging my memory.
  1. Turners check this out!
    By Al Launier in forum General Woodworking Q&A
    Last Post: 01-14-2013, 09:24 PM
  2. For the pen turners
    Last Post: 10-15-2008, 02:33 PM
  3. Hello fellow turners
    By Jim Ketron in forum Welcome and Introductions
    Last Post: 11-16-2007, 02:40 PM
  4. Any top turners out there?
    By Curt Fuller in forum General Woodturning Q&A
    Last Post: 07-04-2007, 02:09 PM
  5. For you turners
    By larry merlau in forum General Woodturning Q&A
    Last Post: 05-18-2007, 12:34 PM
