Results 1 to 10 of 25
Thread: Is the time off for everyone?
    2,784
    I'm guessing the software isn't corrected for the new date change for DST. I'm an hour early on my post. I guess that gives me plenty of time to re-read and correct any problems before anyone notices, huh? Just wondered. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Testing 1, 2, 3
    Nope, it's showing the correct time for me.
    What's the new date change you mentioned? All the references I've seen say it's November 2 this year.
    2,784
    That is correct, but last year was the first year at the new schedule. I just thought maybe the software hadn't caught up with it yet. I did look at my profile before I posted the note, and it shows central time, DST on. I'll check this post and see what it says. Jim.
    Still an hour early. Did they change my time zone and I missed it? Jim.
    OOPS!!! My clock in this room is an hour off!! The clock on my computer is right. HMMMM when did that happen? I'll just blame it on the heat in the attic hooking up the ceiling fan power feed line.
    Carry on. Jim.
    Exclusively Irish!
    2,784
    I just looked...my computer clock is the one that is wrong. The room clock is right. Something tells me the time I see on the post is controlled by my computer's clock. I'm going to change it and see what happens. Frank, I think I'm the one that's getting old! Jim.
    Nope, forum post time is still an hour early. I'm so confused.....
    Exclusively Irish!
    5,323
    Quote Originally Posted by Jim O'Dell View Post
    No problem here. EDST zone...GMT -4 hours.
    Always did think Texas time was a bit off...
    Inside the Beltway
    2,666
    Odd! Now what time is it?
    Odessa, Tx
    1,813
    Time Test
    (This post should come up a @ 11:22 CDST on my computer.
    (OK, so MY computer is 1 minute off) ha!
    ...I did look at my profile before I posted the note, and it shows central time, DST on. I'll check this post and see what it says...
    I just looked at your profile, and you have Automatically detect DST settings set to "Yes", but the Is DST currently in effect option is set to "No". I think if you set the latter one to "Yes", things will display correctly for you.
    2,784
    [quote=Vaughn McMillan;124843]I just looked at your profile, and you have Automatically detect DST settings set to "Yes", but the Is DST currently in effect option is set to "No". I think if you set the latter one to "Yes", things will display correctly for you.[/quot]
    Vaughn, I see the automatic detect, but I don't see the DST currently in effect option. Is it under a different section? Thanks!!
    Norman, your post shows it was made 1 hour earlier than you said it was. So this is still showing I'm off. Jim.
    Exclusively Irish!
  1. Long time lurker first time member
    By James may in forum Welcome and Introductions
    Last Post: 01-29-2016, 06:36 AM
  2. Just in time
    By Charles Hans in forum General Woodworking Q&A
    Last Post: 12-23-2012, 05:47 PM
  3. Last time I try this!
    Last Post: 12-12-2012, 03:56 PM
  4. It's time for a Shed Thread -Time to get the roof on
    Last Post: 10-27-2011, 02:26 AM
  5. Wake Up,, its time to get back at it!!!,, we HAVE enough,next time
    By larry merlau in forum Giveaways, Contests, and Swaps
    Last Post: 01-12-2010, 12:37 AM
