Results 1 to 3 of 3
Thread: Non-toxic oils or waxes for finishing bowls
    Lots of questions tonight! ... I've been meaning to post these for awhile.
    Any recommendations for oils or waxes that I can use to finish my bowl that are non-toxic and make the bowls safe for eating with?
    Aug 2008
    Reno, Nv
    3,632
    Bernie and many others had some great ideas on this a few weeks ago. I use bee's wax a lot. Mike Mahoney and others have a good walnut oil. Do a search for finishes or just look back a week or so under general turning ?'s. Several things I want to say are fact, but check with the previous posts...it was a good series.
    Always ask as many questions as needed, chances are good that someone else is wondering the same thing. There is no shortage of good/friendly/supportive advice here.
    Goodland, Kansas
    4,834
    Ask away that is what this forum is for. All finishes today are food safe if let dry for a minimum of 72 hrs. I don't use wax much because it doesn't last. I do at times use Mike Mahoney's walnut oil and then after that has dried his walnut oil/wax mixture. So far I have used Minwax Antique oil which by the way is the only food finish Ernie Conover uses on his utility pieces. I use a lot of General Finishes Seal-A-Cell and Arm-R-Seal. You put the Seal-A-Cell on first then follow it with Arm-R-Seal. It is a great finish. I used this on two salad bowl sets I made for my boy and his family. The other was for my brother and his family. In each set there were 10 small salad bowls (7") and the big one 13" X 5". They have been used now for almost two years and still look great. I have a cereal bowl I have used now for almost two years with the same finish and still going good. Basically I use Antique Oil (3 coats) or General Finishes on all my food stuff.
    Bernie W.
  1. All microcrystalline waxes not equal
    By Ryan Mooney in forum Finishing School
    Last Post: 05-17-2014, 11:22 PM
  2. Finishing for Bowls
    By Daris Robertson in forum Turning Tool Questions and Show & Tell
    Last Post: 08-26-2013, 12:37 AM
  3. best penetrating oils
    Last Post: 12-12-2012, 12:02 AM
  4. Toxic Mulch
    By Chuck Beland in forum Off Topic Discussion
    Last Post: 03-09-2009, 08:33 AM
  5. Finishing questions on bowls
    Last Post: 12-06-2008, 04:04 PM
