Results 1 to 6 of 6
Thread: Wolvie Clone
    5,533
    Wolvie Clone
    Found the fww King Heiple plans online yesterday, and decided to make one today. I'm about halfway through at the moment, most of the parts are cut and the 'hardware' is on hand (several t nuts and thumb screws). Pics later tonight.
    -Ned
    11,833
    Should be a great project. Yes, definitely need pictures.
    Sacramento, CA
    1,367
    Dang, that's pretty cool - i once made one of wood, too - when i was using my belt sander. It worked okay but had a little flex on my longer tools. Then I went for this:
    http://www.sacramentoareawoodworkers...s.php?album=14
    I've since built v3 with steel and plan to get it all mounted up one day - pics when i do
    Jason Beam
    Sacramento, CA
    5,533
    Fired up the ts a lot tonight... and other than thin ripping, I like my new rockler featherboard.
    Just mocked up there, the base is complete, and the rails, but only one tnut is installed and I still have to mount it at 4" from the platform, as well as swap the tnut for one which has 'teeth' (managed to buy the ones without) but since my grinder currenly only has one wheel, It isn't a critical need. I also need to recut the v-block. My initial cut was more than a little off.
    -Ned
    That looks like it should work fine. Next, I'd suggest finding a plans for a Varigrind clone...it'll make getting the Ellsworth-style grind much easier.
    5,533
    The plans I reference have a shop built gouge holder, which I didn't get to before I decided I was done for the evening.
    -Ned
  1. Good Fein Multimaster clone?
    Last Post: 02-01-2012, 08:58 PM
  2. grinder w/ wolvie jig in Syracuse cl-list
    By Ned Bulken in forum Hot Deals
    Last Post: 10-30-2008, 12:27 AM
