Results 1 to 4 of 4
Thread: Gouge profile ?
    5,533
    Gouge profile ?
    One of my Disston gouges has this profile...
    Another view
    I realize this is a spindle gouge, but I'm thinking about regrinding this with more of a fingernail grind. Any pros or cons on this line of thought?
    -Ned
    Goodland, Kansas
    4,834
    Ned all of my spindle gouges have the fingernail grind. I find them easier to use and I can do cuts with them easier than the conventional grind.
    Bernie W.
    Aug 2008
    Reno, Nv
    3,632
    Fingernail grind is the preferred grind of late. It allows for a better shear and cuts way down on catches inside bowls and HF's. I still use a traditional grind on 2 spindle gouges. IMHO there is better heat dissipation on dry stock and I get a wider cut. Fingernail is still my favorite for 75% of my rookie work and I'm sure it will increase as skills do
    Jan 2008
    Stow, OH
    151
    The continental gouge is not as strong as a round gouge when using as flute up.
    When the gouge is lay on its side at about 2:30 or 9:30 o'clock, its broad edge gives a very nice shearing action.
    Russ Fairfield has shown it on the bottom of this tool grind page:
    http://www.woodcentral.com/newforum/grinds.shtml
    This type of gouges are getting quite expensive now.
    When using on bowls, it is meant to be used as finish cut, tool rest close, no long overhang over the tool rest. It has the same weak tang as most SRG (spindle roughing gouge).
    Gordon
  1. Low profile cnc vise
    By Darren Wright in forum Programming, Troubleshooting, and Q&A
    Last Post: 04-20-2016, 09:39 PM
  2. Profile matching
    By Steve Southwood in forum Flatwork Project Showcase
    Last Post: 04-27-2013, 03:50 PM
  3. Bent my bowl gouge.. a 5/8" bowl gouge
    By Chuck Ellis in forum General Woodturning Q&A
    Last Post: 09-01-2010, 12:57 PM
