Results 1 to 10 of 21
Thread: Wood slicer bandsaw blades any comments?
    Catalunya
    4,632
    Has any of you tried the mentioned blades? Are they as fantastic as they advertise specially for resawing and cutting veneers?
    Any info will be greatly appreaciated
    Thanks in advance.
    Best regards,
    Toni
    toni,
    i buy my carbon steel blades from ellis mfg.they`re good blades at a fair price.
    to be fair i`ve never used the woodslicer because it`s about 3x the cost of what i buy and in my opinion a carbon blade is only good unitil it starts to dull..........i`d rather have three sharp blades instead of one.
    30,002
    Toni, I have a Woodslicer that I've used for resawing on my 14" (with riser block) bandsaw. It cuts slower, but smoother than any other blade I've used on this saw. If the saw is set up right, it'll cut slices out of 6"+ material that require only minimal sanding.
    Tod does have a good point about buying three sharp blades for the price of one, and especially in a production environment like his, it makes sense. He has a lot better tools for smoothing up the cut afterwards than I do, though.
    Catalunya
    4,632
    Tod, Vaughn.
    Thanks for the info,I was asking because I thought about trying one, but at 29$ each plus shipping to Spain I wanted to be sure it was worth the price.
    So maybe I'll leave it for later
    BTW Vaughn. Is that "bagheadman" of your avatar you?
    Best regards,
    Toni
    30,002
    ...BTW Vaughn. Is that "bagheadman" of your avatar you?
    It's probably someone you would know only if you watched a lot of American TV:
    http://en.wikipedia.org/wiki/Unknown_Comic
    Catalunya
    4,632
    Thanks for broadening my knowledge Vaughn. Now I know a bit more than yesterday.
    Best regards,
    Toni
    toni, look locally for a blade supplier, i`d suggest a 3t hook blade with as wide a body as your saw will support for resawing.
    the species and height of the wood, wheel size of your saw and horsepower of the motor all have bearing on blade choice....
    Waterford, MI
    773
    I used to keep Woodslicers on my 14" Jet+Riser but sold that when I got the Minimax with a Lenox Trimaster. The WS works extremely well when it's sharp but seems to dull a bit sooner than I think it should but I dont really have anything to compare it to. I was using the WS pretty much right after buying that saw. Check with Iturra (I dont think they have a website yet). I've read that they have the same blade under another name and they may have better prices than Highland Hardware. Iturra's catalog is well worth having even if you dont buy blades through them.
    Catalunya
    4,632
    Thanks Tod.
    What do you mean by "3T"? 3 teeth per inch? and as far as the width is concerned would you say that a rule of thumb would be: the harder the wood the wider the blade or the opposite?
    Dough.
    Thanks for the info, I thought that Iturra only made blade guides and similar. I'll try to get their catalog.
    Best regards,
    Toni
    yup 3 teeth per inch..........the width has nothing to do with the wood density it`s all about tracking straight in the cut.......smaller saws don`t have the spine strength to tension a wide blade so look to your saws manufacturer for width recomendations.
  1. Bandsaw Blades
    Last Post: 01-07-2014, 04:29 PM
  2. bandsaw blades
    By Dan Diel in forum General Woodworking Q&A
    Last Post: 05-19-2009, 07:20 PM
  3. Bandsaw blades
    By Lee Laird in forum New Tools
    Last Post: 06-07-2008, 12:27 PM
  4. what bandsaw blades do you use ?
    By jim capozzi in forum General Woodworking Q&A
    Last Post: 11-12-2007, 02:44 AM
  5. bandsaw blades?
    By Brent Grooms in forum New Tools
    Last Post: 12-12-2006, 06:02 PM
