Results 1 to 3 of 3
Thread: Table Saw power question
    Palm Springs, Ca
    1,169
    I put a new motor on the table saw i had - 1 1/2hp, 220v and got it working today. I pluged it into the the 220 outlet i have in the garage for the dryer (same one im using for my Jet lathe) and it works great for about 30 seconds and then trips the breaker in the electrical panel. However, it never trips the breaker when im using my lathe.....
    Anybody got a thought on this.........thanks Dan
    Attached Thumbnails Attached Thumbnails tablesaw redone (600 x 450).jpg   new motor (600 x 450).jpg
    Villa Park, CA
    1,407
    I'd suspect you might have something wired wrong on your motor. It certainly should not trip the breaker (unless you have an awful low amp breaker) - a 1.5HP motor should not draw that much current, especially with no load.
    It could also be a bad motor but if it's new, or if it worked fine in the previous application, that's somewhat unlikely.
    Are you sure it's properly wired for 220V?
    Mike
    Ancora imparo
    Palm Springs, Ca
    1,169
    Yeah im going to have the wiring looked at.............Thanks Dan
  1. Shop power Question
    Last Post: 11-30-2012, 04:31 AM
  2. 220 Power Question
    By Cynthia White in forum Carpentry and Construction
    Last Post: 11-04-2010, 05:42 AM
  3. Oak Slab Table Build - Hand Power Only (so far)
    By Jeff Bower in forum Handtool Project Showcase
    Last Post: 04-01-2010, 05:13 PM
  4. shaper and power feeder question
    By Chris Mire in forum New Tools
    Last Post: 09-01-2007, 02:07 PM
  5. WANTED - Power feeder for router table
    By Al Navas in forum Old Ads
    Last Post: 03-06-2007, 03:19 PM
