Results 1 to 3 of 3
Thread: Corner Spline Jig
    Michigan
    2,436
    Corner Spline Jig
    The jewelry boxes I made
    http://familywoodworking.org/forums/...2075#post12075
    needed to have something to set off the corners so I thought I'd try my hand at corner splines, but first I needed a accurate and safe way to cut these using my crosscut sled.
    Following are some pics of the pieces I needed and making it work.
    I started off with 2 triangular pieces of 3/4 ply and a rectangular piece of 3/8"
    I glued it up and nailed it together aligning it with my crosscut sled.
    Next I made some lines on the sled to align me up for a left and a right cut.
    Set the blade to a height to not cut through the inside of the box, and made my cuts on the right side first, flipped the box and made my cuts on the left side.
    I cut the spline material simply by setting up the fence to the correct width and run it through.
    Jig is simple, cheap, and works.
    Attached Thumbnails Attached Thumbnails 100_2839.jpg   100_2840.jpg   100_2841.jpg   100_2849.jpg   100_2845.jpg
    15,816
    Very cool, and, especially important for me, SIMPLE!
    Floydada, Tx
    1,941
    Looks good. I also seen in one of the magazines where they used a biscuit joiner to make the slots.
  1. Poor Mans Dovetail Spline Jig
    By Roy Millsaps in forum Jigs and Fixtures
    Last Post: 10-29-2014, 03:15 PM
  2. Clever router based mitre spline jig does dovetails too
    By Rob Keeble in forum Jigs and Fixtures
    Last Post: 09-28-2014, 12:40 PM
  3. Miter Spline Jig
    By Ned Bulken in forum Jigs and Fixtures
    Last Post: 08-17-2012, 02:51 AM
  4. Oak Corner Table
    By Jim DeLaney in forum Flatwork Project Showcase
    Last Post: 12-10-2011, 11:54 PM
