glenn bradley
- SoCal
Glenn, is that an electrical panel behind the main duct? I assume you left enough clearance to get into it to reset breakers, but how about service? Most codes require an unobstructed access of 36" in front of the box.
Yep, there is plenty of room to work on it but the 36" clearance is in violation. If 'someone' was coming, that section of the duct is removable:
but as it will be used; it is not kosher.
While I had the section out I converted it to a 6x6x4 WYE and brought the overarm guard back into play:
I just close the gate, pull off the quick connect and let it hang when the arm is swung to the non-use position.
