Results 1 to 7 of 7
Thread: Soffit Install Help
    Melbourne, FL
    472
    Soffit Install Help
    Frank - I am asking the experts at FWW.
    Another question-
    I see that the soffit is genarally screwed into the wood facia board and covered with a piece of Vinyl Fascia.
    My application is as in the bottom example in the picture.
    J Channel is on both inner and outer ends of the soffit. How do you fasten the soffit in this situation?
    17,470
    i dont see how you would i have always used the first methode you show.. i woudlnt want mine to be loose like the second methode..have youa lread got the frt jmold in ? maybe mr ash will come back to respond to this he is the current authority here. send him a pm pete
    Southern Louisiana
    947
    pete,
    i am not a siding guy, but around here they usually do the first method with the fascia. also, the soffit is prepped with 1x4's running the length of the soffit, giving something solid to nail to along the entire length. i can't remember all the terminology, but there is usually a 2x4 piece running from the end of the rafter, back to the top plate. the 1x4's are secured to this.
    is your application just all open under the soffit?
    Pete,
    Is the soffit aluminum or vinyl T&G? If so, is there space to run blocking down the middle? The installation of the last piece can me a challenge, but at least it will be secure.
    Another idea is to use F-molding front and back. The soffit sections would need to be slid into place - a progressive installation - instead of running all of the molding, then all of the soffit.
    There are pros and cons to each method. Just food for thought.
    Wes
    Melbourne, FL
    472
    Vinyl
    It is a replacement so the wood fascia setup is pretty well going to stay as is.
    It is Vinyl Soffit that is being installed.
    Rev 1 -
    Looks like most areas of the soffit have a 2x6 up in back of the wood facia.
    So I can put J channel on both the inside and outside, slide the soffit in from one end and deal with 1 end piece which will be difficult.
    I will try to work so as to have the least number of end pieces that I can.
    Michigan
    2,436
    Thanks bozz....
    Here ya go Pete
    http://www.certainteed.com/CertainTe...lation/#Soffit
    I use example #3 mostly
    Odessa, Tx
    1,813
    Quote Originally Posted by Steve Ash View Post
    Thanks bozz....
    Here ya go Pete
    I installed about 65' of vinyl soffit material as the ceiling of an L shaped porch using method 2, 18 years ago, and it is still there and looks like it did when I installed it. (just my experience), YMMV.
  1. RapidAir Install
    Last Post: 08-02-2012, 07:22 PM
  2. Should I install 3 phase?
    By Brian Altop in forum Carpentry and Construction
    Last Post: 02-12-2011, 12:57 PM
  3. Another Dust Deputy Install
    Last Post: 12-27-2009, 03:09 AM
  4. Kitchen for my son! The Install
    Last Post: 08-30-2009, 03:07 PM
  5. Vinyl siding and soffit cutting jig
    By Steve Ash in forum Jigs and Fixtures
    Last Post: 12-16-2006, 11:54 AM
