Results 1 to 10 of 20
Thread: drill press & Bandsaw table
    Nov 2008
    Louisville, Kentucky
    161
    Hi All
    Has anybody got a plan for a simple Drill press or Bandsaw Table? I don't need anything fancy just table with a fence.
    thanks
    Larry
    I have a very basic table on my saw, I looked, but I did not see a post about it, maybe I missed that one
    I'll take a few shots and post tonight about it.
    It is very basic but works fine.
    Nov 2008
    161
    thanks Stuart Does it have a fence ? How does it lock to the Press. I have a Delta 12" table Top model
    LATTY
    Nov 2008
    161
    CAN'T EVEN SPELL MY OWN NAME
    Larry
    Odessa, Tx
    1,813
    Quote Originally Posted by Larry Hibbs View Post
    Larry
    That's OK, we's used to it, 'cause Spellin' seems ta be a Genetic thing with guys named "Larry".
    30,008
    Larry, although the fence may be fancier than what you're looking for, this thread might give you a few ideas:
    http://familywoodworking.org/forums/...ead.php?t=8090
    I fabbed up my own fence for my Gilliom Bandsaw...you know one of those bandsaws you make from a kit. Anyway I used a fence from an old tablesaw and grafted it onto the bandsaw table. I don't have a picture of it though.
    OK Larry, here you go...........
    Here is the basic table, I used two 15mm thick pieces of plywood, glued together.
ID:	25793 Click image for larger version.
    Before I glued the two pieces of plywood together, I drilled holes and inserted four bolts, this way I had an easy way to attach the auxiliary table to the steel table on the drill press.
    Here is the router set I bought from Rockler to make the "T-slots", I've used these many times, a very useful purchase
ID:	25794 Click image for larger version.
    You can see the simple fence I made, and the back side of it, works well, took minutes to make.
    The sacrificial insert is 10cm x 10cm I drilled the holes on the corners to make it easier to take the insert out.
ID:	25798 Click image for larger version.
    You can rotate the insert to give you a fresh bit to drill into.
    You can also swing the table a bit to one side to use another fresh space on the insert..............
    One last pic, I just wanted to mention this, I did not put any finish on the table, I figured this is really a "prototype" so why bother.......... I'll most likely use if for years to come
    I do a fair bit of metal work as well, and instead of removing the table each time I want to drill some steel, and use cutting oil, and to keep the mess at bay, I have a small lid from a cookie tin.........
    .......simple, easy and cheap, I like it
    Alexandria, Virginia
    1,071
    Stuart you continue to impress me with your shop capabilities.
    I really like your simple, functional, design and your clever use of a cookie tin lid to capture metal filings. Do you, or have you, thought to stick a magnet on the outside of the tin to help capture the filings; and can be removed when it is time to dump the filings?
  1. Drill Press Table
    By Darren Wright in forum Jigs and Fixtures
    Last Post: 10-28-2014, 03:22 AM
  2. Drill press table
    By Roger Tulk in forum Jigs and Fixtures
    Last Post: 05-01-2013, 08:52 AM
  3. Drill press table
    Last Post: 01-16-2012, 05:58 AM
  4. Drill Press Table
    By Roy Bauman in forum Jigs and Fixtures
    Last Post: 08-19-2011, 06:04 AM
  5. Drill press table???
    By Chuck Beland in forum General Woodworking Q&A
    Last Post: 02-16-2008, 06:42 PM
