Results 1 to 10 of 14
Thread: Bandsaw blade tension
    Nov 2008
    Ottawa, Ontario, Canada
    34
    I recently purchased a grizzly G0555X and added the riser kit. This is my first bandsaw and I'm not sure if I have the tension set properly.
    I tried to follow the instructions in the manual.
    "Release the tension one quarter of a turn at a time. Do this very slowly. When you see the bandsaw blade start to flutter, stop decreasing the tension. Now, slowly increase the tension until the blade stops fluttering, then tighten the tension one more quarter of a turn."
    I must be doing something wrong (old eye's) because I can't see the blade fluttering.
    Help!!!!!!!
    Bruce
    Alexandria, Virginia
    1,071
    Bruce I hope you don't mind but, without answering your question, may I add an additional question to it?
    Assured your answer is yes; Is it best to relieve tension on a bandsaw blade between uses?
    17,475
    frank your questions answer is: yes,,, it saves the tire from taking a set and inducing early failure..which is what maintains your accuracy of cut to some extent
    1,071
    Thank you Larry!
    17,475
    fluttering
    bruce mine arent as old as yours but i can have troubles too at times,, there was a article in wood magazine a while back that described this adjusting thing very well.. i go by the feel of the tension and a cut against it i belive there sis another way of checking by using the guides all the way up and testing the deflection of the blade by hand and adjusting from there,, but older hands may have lost the strength as well so look for the wood mag azine ad
    Nov 2008
    34
    thanks Larry I'll try to find it.
    Bruce
    9,077
    Frank - Yes.
    Bruce - Are your guides completely backed off while you attempt to find the flutter spot? When I reach the flutter spot on my saw, if the guides were in place they would prevent the flutter. When I hit the flutter spot, there is no problem seeing it. It is quite unnerving and kinda dangerous looking ;-)
    Here are the complete instructions from Suffolk specific to their Timberwolf blades but I do the same thing for any non-specialty (carbide, bi-metal) blade:
    FOR TURN SCREW AND SPRING TENSIONING MACHINES
    1. Remove guides--you CANNOT run this test if the band saw blade is restricted in any lateral movement.
    2. Make sure tire surfaces are in good condition--they cannot be hard, flattened out, cracked or brittle. On mills with loose fitting V-belts, replace them with the next size down so they are tight fitting. This will eliminate over 80% of the vibration in your mill and the blade.
    3. Mount the blade on the machine and apply the tension to the band that the manufacturer recommends for other steels.
    4. Close all covers for safety purposes.
    5. Start the machine, engage the clutch into the high speed cutting mode. NOTE: You will not be cutting any wood.
    6. Stand at the head of the machine, with your hand on the turn screw tensioner and your eyes on the band saw blade. Very slowly start detensioning by half turns at a time, keeping your eyes on the band saw blade. The object is to bring the tension of the blade down to a point that the blade starts to flutter. TAKE YOUR TIME.
    7. When you see the band start to flutter, you have hit ground "ZERO". Now start ADDING quarter turns of tension, SLOWLY, until the band stops fluttering and is running stable again. At this point ADD one-eight to one-quarter turn of tension.
    8. You have now tensioned our blade correctly. Shut off the machine and put your guides back in place. You are now ready to start sawing.
    9. ALWAYS DETENSION YOUR BAND SAW BLADES. Since you do not know exactly where the proper tension is, it will be easier to remember if you take off 8, 9, or 10 full turns of tension until the band is completely relaxed. The next time you use our bands, add the same amount of turns of tension that were taken off. At this point, you will only have to run the flutter test one time.
    HTH,
    Glenn
    1,071
    Thank you Glenn!
    i "pluck" my blades `till they sound right.......and i don`t release the tension either.
    Nov 2008
    34
    Glenn< Thanks a lot. I will make sure the guides are backed right off and try again.
    Bruce
    Bruce
  1. Bandsaw Blade ?
    Last Post: 03-28-2015, 08:41 PM
  2. bandsaw blade tension question
    By John Jussel in forum General Woodworking Q&A
    Last Post: 12-11-2011, 03:31 PM
  3. Delta bandsaw Tension
    By Larry Fredric in forum General Woodworking Q&A
    Last Post: 02-15-2010, 12:01 AM
  4. Audible bandsaw tension gauge
    By Phil Thien in forum General Woodworking Q&A
    Last Post: 05-25-2009, 07:23 PM
  5. Bandsaw tension problem
    By Westley Rosenbaum in forum General Woodworking Q&A
    Last Post: 12-08-2008, 02:59 PM
