Results 1 to 10 of 12
Thread: wipe on poly
    Southern Louisiana
    947
    wipe on poly
    if you have used this before, how many coats did you put on?
    i am finishing my bamboo cabinets with minwax wipe on and i am on the 3rd coat. sanded after 2 coats. i think it looks good with three. is 3 coats enough of this stuff?
    Constantine, MI
    7,892
    Just me, but I usually go to 5, though I have gone to 7 once or twice for high use items like a table top. After the second coat I switch to 0000 steel wool between coats.
    www.wrworkshop.com
    Toronto, Ontario, CANADA
    2,332
    I use wipe on poly a lot. I started with the stuff that you can buy from Minwax and, more recently, have been making my own. I usually use three coats but have used as many as 5.
    Cheers, Frank
    Southern Louisiana
    947
    thanks rennie.
    ok frank, i'll bite, how do you make your own? thin it?
    The usual mix is about 50% varnish and 50% mineral spirits and the rule of thumb is three coats of wiping varnish equals one coat brushed. The neat thing about mixing your own is you can tweak the amounts to suit the project. Although I am sure no one except me is interested but you can also save some money.
    Regards
    Jerry
    2,332
    Quote Originally Posted by Chris Mire View Post
    I mix 3 parts Watco or Deft Danish oil (uncoloured) with one part oil-based varnish (such as Helmsman). With this, I wipe it off immediately and usually apply 5 coats. I thank Hendrik Varju for this formula and technique.
    Cheers, Frank
    Oct 2008
    1,357
    I've had good luck with 50% poly and 50% naphtha. Got that recipe from a finisher by the name of Jim that used to post on WOOD finishing forum. I used about 3-5 coats.
    Aloha
    Aloha,
    Thomasville, GA
    6,000
    Like Royall, I've used a 50/50 (or 1/1) mix of poly and naphtha. I've also used other combinations depending on what I was doing. Other combos are:
    BLO/Naphtha/Poly - 1/1/1
    Poly/Naphtha - 1/2 and 1/3
    BLO/Naphtha - 1/1, 1/2 or 1/3
    Various combos for specific situations.
    Bill Arnold
    17,475
    where is a good source for naptha? i have some but my source is gone. it was used in a press for clean up.
    Oct 2008
    1,357
    I spotted some at HD last week. It was over in the paint department. ACE had it too.
    Aloha
    Aloha,
  1. New way to do wipe on poly
    By Mark E Smith in forum General Woodworking Q&A
    Last Post: 04-07-2016, 11:41 PM
  2. wipe on varnish formula
    By Rich Soby in forum Finishing School
    Last Post: 01-15-2015, 01:39 AM
  3. Minwax Clear Satin Wipe on Poly and Min Wax Sanding Sealer
    By Mike Turner in forum Finishing School
    Last Post: 12-14-2014, 11:18 AM
  4. Box Elder - Follow up Question regarding Wipe on Poly
    Last Post: 02-24-2012, 02:26 PM
  5. Wipe on Poly on Padauk problem
    By Keith Palmer in forum General Woodturning Q&A
    Last Post: 12-11-2008, 02:55 PM
