Results 1 to 10 of 16
Thread: 4th Annual WorkShed Clean-Up and Improvement "Week"
    Toronto, Ontario, CANADA
    2,332
    (part 1 of 4)
    Every year since I built my woodworking shed/shop I have devoted a week in November to clean up, repairs and improvements. To read about the 2007 week, http://familywoodworking.org/forums/...ead.php?t=6656.
    The week starting November 10th was supposed to be that week and I did get started on the task. But, there were so many non-shop tasks right now that I managed to devote fewer than 20 hours to it. So, I extended the week to a fortnight. That fortnight ended last Sunday.
    The biggest task was to clean and to clear all the clutter, but I did get to build a few things.
    In the first week, I only completed two jobs, one a repair job and one an improvement. The repair was the replacement of a broken wooden top section:
Name:	x Workmate Repair 1 -Broken part -small.JPG
    on my about 30 year old Black and Decker Workmate. The first thing to do on this repair was to laminate a plywood part with the same dimensions as the broken section. I used two layers of 12mm Baltic Birch. The broken part was used as a template to mark the hole locations, then holes were drilled using my drill press:
Name:	x Workmate Repair 2 -Broken part is used as a template for hole locations -small.JPG
ID:	26004 Click image for larger version.
Name:	x Workmate Repair 3 -Holes drilled on drill press -small.JPG
    I put three coats of spar urethane on the new part then attached it. But, there was a problem. I thought that the holes would be inch, but it turns out that they are 2 centimetres. My Workmate was made in Canada about 30 years ago and I guess that they had converted to metric at the time. I wonder if the new ‘made in China’ Workmates have metric sized holes. 2 centimetres is only a little bit bigger than inch, so drilling the holes slightly larger was tricky: Click image for larger version.
Name:	x Workmate Repair 4 -Increase hole size from .75 inch to 2 cm -small.JPG
    After drilling, I smoothed the edges with a roundover bit: Click image for larger version.
Name:	x Workmate Repair 5 -Roundover edges -small.JPG
    Then, I applied a couple more coats of spar urethane all round and re-assembled it: Click image for larger version.
Name:	x Workmate Repair 6 -Replacment part in place -small.JPG
    There is a rather dramatic contrast between the surviving old section and the new section but everything lines up well.
    The improvement was a place off the floor to store my small band saw. There is a section of wall at the north end of the west wall that has not been fully utilized:
Name:	x Some wallspace available -small.JPG
    It is mostly used to hold the carrying box for my Festool rails but the rails now mostly reside in the garage and the box is has seldom been used during the last three years. I decided to put the box in the garage and to use the wall space for cabinets to hold the small band saw as well as some systainers. The portion of this that I completed was the place to hold the band saw:
Name:	x Rollers for small bandsaw platform -small.JPG
ID:	26000 Click image for larger version.
Name:	x Bandsaw on platform on rollers -small.JPG
    Cheers, Frank
    2,332
    (part 2 of 4)
    In the second week, I found almost 30 hours to devote to the job, and got a lot more done.
    I had a few systainers that had to sit on the floor due to insufficient drawers. My inventory is 19 systainers and there were only 14 drawers. One fits on the vacuum leaving 4 to kick about somewhere. I figured that there was room for at least 8 more shelves to the right of the space that I used to store the small bandsaw. In that these shelves will not be rolling around, I decided on a minimalist design, actually little more than a tray where the sliders form the sides of the tray. Click image for larger version.
Name:	x Simple Systainer drawer 1 -bottom front and back glued and screwed together and pilot holes dr.JPG
ID:	26009 Click image for larger version.
Name:	x Simple Systainer drawer 2 -drawer slides used as side lips -1 -small.JPG
    I decided to pre-drill holes in the carcasses in order to accommodate different configurations of systainers. Here are three different ways that the shelves can be organized:
    sys1-sys1-sys2-sys2-sys1: Click image for larger version.
Name:	x Systainer cabinet configured for-sys1-sys1-sys2-sys2-sys1 -small.JPG
    sys1-sys1-sys2-sys4: Click image for larger version.
Name:	x Systainer cabinet configured for-sys1-sys1-sys2-sys4 -small.JPG
    sys2-sys2-sys2-sys3: Click image for larger version.
Name:	x Systainer cabinet configured for-sys2-sys2-sys2-sys3 -small.JPG
    Here is the current set up of the drawers:
Name:	x Shop wallspace now utilized -top -small.JPG
    I now have 4 shelves free for future purchases. I still have one systainer maxi living on the floor, but I guess that will be a challenge for next year’s Clean-Up and Improvement week.
    Cheers, Frank
    2,332
    (part 3 of 4)
    Another task involved a systainer. I have been storing a hammer drill in a Sys2 systainer for about three years, but I have simply been placing the drill and accessories in the systainer and letting them rattle around. Until yesterday, the hammer drill kept in my systainer was a DeWalt. But that drill has been problematic for some time. The problems have to do with loose wires and a faulty switch. I have (sort of) fixed it at least three times and had a certified repair centre fix it once. Yesterday, I gave up on the drill and it is now history.
    For the last year or so, I have also owned a Milwaukee Hammer drill for use as backup. It has now been promoted. To celebrate the promotion, I decided to organize the systainer. I also spray painted the latches dark red as an assist to locating the correct systainer. Below are two pictures of the interior: Click image for larger version.
Name:	x Systainer Organized for Milwaukee Hammer Drill -2 -small.JPG
ID:	26019 Click image for larger version.
Name:	x Systainer Organized for Milwaukee Hammer Drill -3 -small.JPG
    In September, some of the stuff used to cover end cuts of pressure treated wood spilled into one of my router bit drawers and dried there. Fortunately the bit holders are attached to a plywood insert. I cleaned all the bits to which the stuff had adhered, removed that plywood insert, and made a new one. Click image for larger version.
Name:	x Router bit drawer damaged with preservative leak -small.JPG
ID:	26017 Click image for larger version.
Name:	x Router bit drawer with new insert -small.JPG
    For something completely different, I decided to make a collage of Lee Valley catalogue covers augmented with some cut-outs from their calendars.
Name:	x Lee Valley collage on shed wall -1 -smaller.JPG
ID:	26015 Click image for larger version.
Name:	x Lee Valley collage on shed wall -3 -smaller.JPG
    I had fun doing this and the wall looks very good!
    As usual, there were a lot of trivial repairs that had to be made. For instance, the plastic surrounds on the fluorescent light fixtures are very flimsy and easily broken. I have not been able to find sturdy replacements and a couple of them have been knocked out and cracked. I made some wooden brackets to hold them in place. Click image for larger version.
Name:	x Light surround support bracket -small.JPG
    Cheers, Frank
    2,332
    (part 4 of 4)
    Here are two pairs of before and after photos of the shed/shop:
Name:	x Shed cleanup 03A -Before -small.JPG
ID:	26022 Click image for larger version.
Name:	x Shed cleanup 03B -After -small.JPG
Name:	x Shed cleanup 06A -Before -small.JPG
ID:	26024 Click image for larger version.
Name:	x Shed cleanup 06B -After -small.JPG
    Cheers, Frank
    Oliver Springs, TN
    1,726
    Great job Frank, looks really good.
    Alexandria, Virginia
    1,071
    Frank, it is always a pleasure to read your posts, great job this year, excellent use of space. Also great idea on use of the catalog covers; do send them a picture.
    Happy Thanksgiving to you and your family!
    Floydada, Tx
    1,941
    Looks really good in there.
    3,134
    Lookin good Frank. So why not do this a bit more often & it wouldn't take so long?
    2,332
    Thanks Bart. I don't have a good answer to your question. All I can say is that once a year seems to work well for me.
    Cheers, Frank
    Odessa, Tx
    1,813
    Isn't it amazing how much more room there seems to be in a shop when it is all cleaned up & NO PROJECTS going on.
    Looks Good, Frank.
    You mentioned enlarging the holes that were drilled too small, and it being a bit tricky, so I thought I'd mention a couple of methods I have used to make it easier to keep the alignment the same, just in case someone else might run into this situation. One method is to glue a dowel or plug in the hole then remark the center and drill out to the new size, but the method I have found the easiest, (and fastest), is to drill the proper size hole in a piece of scrap, (preferably with a forstner bit) and then visually center it over the smaller hole and clamp it in place and then use a forstner bit to drill the larger hole in the workpiece. The hole in the scrap acts as a guide for the forstner bit to get started and it works really well (and no tearout).
  1. Cheap "Grip-it" clamps repair and improvement
    Last Post: 03-29-2008, 12:46 AM
  2. 3rd Annual Shop Clean-Up and Improvement Week (completed)
    By Frank Pellow in forum General Woodworking Q&A
    Last Post: 11-19-2007, 01:06 AM
  3. "What to clean bare wood with"???
    By Lary Grassmeier in forum General Woodworking Q&A
    Last Post: 04-08-2007, 12:09 AM
  4. 2nd Annual Shop Clean-Up and Improvement Week
    By Frank Pellow in forum Carpentry and Construction
    Last Post: 11-21-2006, 03:41 AM
