Results 1 to 8 of 8
Thread: Sliding table
    Oct 2008
    1,357
    Sliding table
    Just curious what do sliding tables usually run? Any plans for making one? Will they work on a left tilt unisaw? I'm finding I'm doing more cabinet work than I planed on and think a sliding table may make life easier.
    Aloha,
    royall, generally good extention tables are much more usefull than aftermarket sliders.
    I put a JET sliding table on a JET Xacta saw and it was awfully difficult to install so it was 'right'. The fence on the slider was somehow in the way more often than not... so I'll echo the other comment. Altho it came in handy occasionally, I was never happy with it.
    Royall, I put an Exactor on my ShopFox left tilt cabinet saw & it worked great. Once you use a sliding table you'll wonder how you ever got along w/o one.
    About 5 years ago I sold most of my stand-alone machines and bought a used Robland X31. It comes from the factory with a sliding table. I've done so much with it that would have required way to much 'fiddling' with jigs, etc. on my ShopFox.
    John Lucas has a good demo of installing the Exactor on his website, http://www.woodshopdemos.com/sstat-25.htm
    Manistique, Michigan
    297
    I have a sliding table on my G1023S. I didnt like it until I got a Wixey digital angle gage to help set it up. Now it really works well. I had issues with getting the table to close to the table saw's table or to high. Either way did not give good results.
    Now, I have it set up and I like the performance. I do agree that the miter bar gets in the way.
    I am still not sure that a good sled might not be better.
    Rich (the Yooper)
    "To the world, you may be one person, but to one person, you may be the world."
    "Common sense is not so common."
    Oct 2008
    1,357
    Thanks guys for the input I've been watching the computer out in the shop, and while finishing up the last of the cutting for the boxes and shelves I was thinking of what was said and how I was working. I came to the conclusion that if I move my saw over to the right while I'm standing at it I would have enough room to add another table to help support wider stock to the left of the blade. I've never worked with a slider but they looked cool but it sounds like a real special niche tool that I should pass on. I do have a couple of sleds that I made but they're just not deep enough for cabinet parts that I was cutting.
    Thanks again,
    Aloha
    Photo represents 17 boxes and a pantry for the kitchen I'm working on. Cutting it out is the fun part.Click image for larger version.
Name:	IMG_8232 (Small).jpg
    Aloha,
    royall, if you`re planning to get serious with cutting sheetgoods then a traditional slider might be a wise investment.......but even used they ain`t cheap
    Oct 2008
    1,357
    I'm sure they're not cheap. I got looking closer at the video Frank posted (thanks Frank) and that set up just looked like a lot bucks I figured that I may not get that much work with the economy the way it is here in the Islands to make it pay. If I do get more of this type of work coming in I may look closer at one of the clamp on track type of cutting systems that's out there That would really help in breaking down the sheetgoods.
    Aloha
    Aloha,
  1. 3hp 10 " cabinet saw and sliding table
    By Rich Soby in forum Classified Ads
    Last Post: 02-09-2016, 10:24 AM
  2. Martin T 60 Classic Sliding Table Saw
    By Doug Sinjem in forum Old Ads
    Last Post: 02-18-2011, 03:30 PM
  3. JST-48 Sliding Table - $460 (Not Mine)
    By Don Taylor in forum Hot Deals
    Last Post: 11-17-2007, 09:57 PM
  4. Sliding table for shaper
    By Doug Sinjem in forum Jigs and Fixtures
    Last Post: 11-16-2007, 02:47 AM
  5. PM66 with Sliding Table
    By Rob Bodenschatz in forum Hot Deals
    Last Post: 02-27-2007, 03:02 PM
