Results 1 to 10 of 22
Thread: Bansaw fine tuning question.
    Catalunya
    4,632
    All right, now that I'm going to put a US blade in my saw thanks to Larry, I plan to tune it really fine and here is the question.
    Acording to "The Bandsaw book" the wheels must be aligned and one way of checking that is using a straight stick and placing it against the wheels and it should touch both wheels at the same tine so that both are turning in the same plane.
    However, I noticed that in my saw the previous blade didn't stay on the same part of the lower wheel than in the top one. On the lower wheel is always a bit backward (in the cutting direction).
    Due to that I have the feeling that the wheels are not well aligned. Am I right? or it is normal?
    Moreover, as the upper wheel is the one that we tilt to adjust the position of the blade on the wheel I guess that to check if both wheels are aligned I should first put the top one plumb (vertical) and check the alignment with the lower one. Is that so? Then I could move the lower wheel backwards for the same displacement that the blade has.
    I hope I have explained well what I'm trying to convey.
    Any help will be greatly appreciated.
    Thanks in advance.
    I do want to start fidling around without knowing if what I'm doing is right
    Best regards,
    Toni
    Jan 2008
    Austin TX
    405
    Toni,
    Make sure you have the largest blade your saw can use and have it tensioned to spec. With your straight edge, place it across both contact points of one of the wheels and both contact points of the other wheel. If it doesn't want to touch at all four points, measure how far away the top of the wheel is (if you have it flush with the lower wheel) or how far away the the bottom wheel is (if you have it flush with the top wheel). Both ways should give you the same results. If you determine the wheels are not coplaner while under tension, the measurement you took from the straight edge to the wheel is how much one of the wheels should be adjusted. Some saws use a set-screw that attaches the wheel to a shaft and others are on a threaded rod with washer(s) behind the wheel to establish the correct alignment.
    If you have the type saw that uses set-screws to attach the wheels, I'd start with the straight edge against the upper wheel as your reference and adjust the bottom wheel if needed. If you have the threaded rod and nut attachment, I'd start with the straight edge against the lower wheel as your reference and adjust the top wheel as needed by adding or removing washers.
    Just my thoughts. I'm sure there are others who may have other ideas, too.
    Hope this helps,
    Lee Laird
    Austin TX
    Catalunya
    4,632
    Quote Originally Posted by Lee Laird View Post
    Toni,
    Hope this helps,
    Thanks Lee. I have four equidistant hex bolts holding the shaft of the lower wheel, and a handled screw with a nut on the top one.
    The question is how do I know which on should I take as a reference, because what it looks to me is that the lower one is not on the same plane as the top one even if it is vertical
    Best regards,
    Toni
    toni,
    put a blade on it, crank it up "tight" and cut wood......if or when you find it impossible to track a blade or notice the guides being worn prematurally then start fiddling with wheel adjustment.....
    unless tuning your saw is just something you feel the need to learn now?
    Catalunya
    4,632
    toni,
    Well Tod.... not inmediately but it is something I'd like to learn, besides I believe that if a tool is well tuned it performs better.
    I've got only the band saw and a small jointer thicknesser, so use the bandsaw for most cutting jobs and I will use it soon for making tenons and dovetails, so I guess that if it is well tuned those will come out better.
    On the other hand I understand your point, if it didn't bother me before why should do it now? But to me is like leaving a flaw on a piece. maybe nobody will ever see it but I will always know that it is there
    And yes! you can call me picky!
    Best regards,
    Toni
    picky ain`t a bad thing, neither is having a well tuned piece of equipment but bandsaws are finicky and when i first started messin` with `em i "learned" for lots longer than i intended
    Jan 2008
    Austin TX
    405
    Toni,
    Tod makes some good points. If you still want to proceed, with what you've described I'd reference off of the lower wheel. It sounds like the upper wheel is attached similarly to the Delta/Grizzly bandsaws. If this is so, then you should be able to remove the upper wheel (after completely releasing the tension and removing the blade) via the nut on the threaded shaft. Behind the wheel you will likely see one or more washers that act to shim the wheel into the proper plane. Before you remove the upper wheel, write down the distance from the upper wheel to the straight edge that is still pressed up against the lower wheel's rim. This way you can calculate how many washers to put on the shaft behind the wheel. Remember, this is a balancing act. What may be perfect for one blade could be off for another if they don't require the same tension.
    Good luck. Let me know if any other questions arise.
    Lee Laird
    Austin TX
    Often fellows forget the basics when they set up saws. the guides are not there to guide the blade but rather to keep the operator from pushing the blade.
    When you put on a new blade, the guides (upper and lower) are moved out of the picture, as well as the thrust bearings (upper & lower) Tension & Track the blade so that it rides on the crown of the wheel When the wheels are in alignment the blade (without the guides in play) will ride on both crowns, Top & Bottom. It matters not if the front edges of the wheels are aligned or not.
    Remember that the blade is to ride on the crown, forward of the crown will cause the blade to drift in. Behind the crown will cause the blade to drift out. There is no drift (on a undamaged blade) and you can cut a strip to try.
    Only after the blade is in track should you install the guides and bearings. First the lower bearing is moved in (not touching but thickness of a dollar bill clearance) Next the top bearing (again not touching but thickness of dollar bill clearance) Next the guides (or cool blocks) slid in just after the gullets of the teeth. Again they should not touch, dollar bill again is a good gauge. Both upper and lower guides are locked in place.
    Now you are ready to cut, if it is aligned correctly there should be no drift or wandering. If you are constantly pushing the blade to the side you are feeding too fast or too tight a radius.
    bill, with toni living in spain it`s quite possible that his saw will have flat, non-crowned tires. but your advice about adjusting tracking with the guides pulled out of the way is sound no matter the saw.
    if this saw has flat tires blades wider than 1/2" should be adjusted so the teeth are proud of the tire with about 1/2 of the gullet on and half off.
    Oct 2008
    1,357
    Hey Bill..... Is that dollar bill a pre-inflationary bill or a deflated one?? It may make a difference in the thickness
    Aloha
    PS. Just couldn't pass that one up
    Aloha,
  1. Osprey Setup fine tuning
    By Leo Voisine in forum New Systems and Builds
    Last Post: 01-04-2016, 04:26 PM
  2. Still More Fun with BS DC Tuning
    Last Post: 09-10-2010, 10:03 PM
  3. Coarse or fine - pocket hole screw question
    Last Post: 05-28-2009, 03:48 PM
  4. Bandsaw tuning question
    Last Post: 09-06-2007, 07:36 PM
  5. New Delta 14" bansaw-1 1/2 hp
    By Allen Bookout in forum Hot Deals
    Last Post: 09-02-2007, 01:38 PM
