Results 1 to 7 of 7
Thread: pen turner's kit
    Southern Louisiana
    947
    pen turner's kit
    wanna buy my dad a pen turnin kit. any suggestions on a good one? he has never turned a pen before. i don't know what questions to ask. im sure it's just like everything else. everyone like a different kind, or is it really that important? not sure how different they are. any help is appreciated
    thank
    chris
    11,833
    You can't do much with a kit alone.
    For a beginner, he will need a mandrel and the bushings required for that particular kit.
    I suggest you should pop for more than just a kit and get him some starter tools.
    Normally, I don't reccomend PSI for pen stuff, but they do have a fairly good CD for beginning turners and starter sets. Sometimes they give away the CD, other times they charge. Don't ask me why.
    But, do peruse their catalog and call for assistance.
    You asked how different they are. Have him start with a simple slimline style or something similar.
    BTW, those lower end kits are inexpensive. You may want to crack open the check book for several so he can get some practice.
    Carlyle IL
    350
    slimline pens (7mm) are a good starting point. The top and bottoms are the same length.
    Woodcraft has instructions.
    the Cigar pen (10mm) pens are a bit more complicated and woodcraft's instruction are ambiguous.
    joe
    North West Indiana
    6,099
    Chris, I will assume a few things here and then you can straighten me out on the facts.
    You and dad haven't turned pens yet?
    Dad has turning tools and a lathe? (Skew, bullnosed chisel, parting tool?)
    Dad has a lathe?
    Do either of you have a mandrel? Set of bushings?
    I am trying to determine the starting point to explain what it is dad will need so he isn't frustrated.
    Chris, forget the information above from my original post. I just talked with a mother of one of my students and she had primarily the same question. So thought I would provide this information and it should help. Holler if you need more information.
    http://www.hutproducts.com/prodinfo.asp?number=4502
    This page puts you (or should put you) right on the pen starter kit page. It includes everything needed, wood, pen kits, mandrel, glue, sandpaper, bushings. No lathe or tools. Not a bad price when you check them out singularly.
    Jon
    Aug 2008
    Reno, Nv
    3,632
    Craft Supply (woodturnerscatalog.com) has a great selections of kits and even has starter sets with glue, mandrels and all the junk needed to start.
    If you or dad already has a lathe and basic tools, all you actually need are kits, appropriate bushings and drill bit. Slim line kits will require a 7mm or 9/32 bit. If you have a live center and a dead center for your lathe you will not need a mandrel as you can turn each barrel between centers. Epoxy or CA will work for gluing the tubes into the blanks. Drilling the blanks should be done on a drill press but can be done by hand if careful. Squaring the ends of the blanks will need to be done and using a pen mill works well. Other ways can be devised and work sufficiently enough to assemble with a good fit. You can also check with Ernie at Bear Tooth Woods for kits and supplies.
    Southern Louisiana
    947
    thanks everyone. sorry, i messed up my explanation and question. he has a lathe and some tools, that's it. he will need everything else.
    thanks for the replies.
    chris
  1. Crazy turner or so I think...
    By Toni Ciuraneta in forum Turning Tool Questions and Show & Tell
    Last Post: 11-18-2015, 05:15 PM
  2. Need a turner with a BIG lathe!!
    By Nancy Laird in forum General Woodturning Q&A
    Last Post: 04-09-2008, 01:34 PM
  3. FIRST TIME TURNER
    By Brad Hungler in forum General Woodturning Q&A
    Last Post: 12-30-2007, 05:16 PM
  4. Hello from a Turner
    By Steve Schlumpf in forum Welcome and Introductions
    Last Post: 10-25-2007, 01:20 PM
  5. Turner's Smock
    By Tony Falotico in forum General Woodturning Q&A
    Last Post: 12-13-2006, 07:39 PM
