Results 1 to 10 of 14
Thread: Wipe on Poly on Padauk problem
    Sep 2008
    Tacoma, WA
    84
    I just finished a couple of peppermills for xmas made from laminated Maple, black veneer, and Padauk. I have applied some wipe on poly as I have done with my bowls, but it still remains tacky on the Padauk. It has now been a week in the heated shop at 70-75 degrees.
    Is this a known problem with the padauk? I tried sanding what was there and putting a lighter coat of poly on and same thing.
    Any suggestions to remedy the problem??
    Goodland, Kansas
    4,834
    Keith I think it is the oil in the wood. What I would do is sand it down to wood again if possible, wipe it down with acetone let it flash dry then spray with lacquer since it dries faster. I have had good luck that way. Others may have some idea but there are other woods I have had the same problem with poly. I always wipe them down with acetone before putting on finish.
    Bernie W.
    Sep 2008
    Tacoma, WA
    84
    After the acetone wipe and spray with lacquer can I put poly on top of that or just go with the lacquer? I have not tried lacquer yet on my turnings but now is a good time and I know that it does dry fast. What do yo use for spray lacquer?
    Do you have to wait a long before you can buff out a lacquer finish? I waited 2-3 weeks on the poly.
    Goodland, Kansas
    4,834
    I haven't found spray can lacquer much better than Deft. I have been using it on my turnings now for about 3 yrs. I do the same thing with lacquer and wait 2 or 3 weeks to buff. If I use gloss lacquer most times I won't even buff because of the shine it has. I spray a coat about every 30 minutes and about 3 to 4 coats is all I ever do. I have kinda gotten away from poly especially on my small turnings and on bowls I either use General Finishes Seal-A-Cell followed by Arm-R-Seal. Lately after talking with Ernie Conover I have been using Minwax Antique Oil on bowls. That is about the only finish he uses even on utility bowls and items. Right now I use a cereal bowl finished with Antique Oil which I let cure for a month. I have used it now for about 1 1/2 yrs. and it still looks good.
    Bernie W.
    Drums, PA
    292
    (Thinking out loud here)
    Wood that has large pores can have problem like you mention. Ehat happens is the pores act like reservoirs making it take longer for the finish to dry.
    There are times that the finish can also bleed out for a couple of days keeping the finish sticky
    Tellico Plains, Tennessee
    4,353
    I haven't had any problems with the Paduak in my peppermills that I can remember. I did several from glue-ups that had a lot of Paduak in them. I ran all of them through a buffing system anyway as a final finish and they are very smooth and slick.
    I did some bottle stoppers from Bocote that stayed tacky... they got run through my home made Beall system too, finished off very nicely.
    Chuck
    Tellico Plains, TN
    Waterford, MI
    773
    I haven't run into that with Paduak but kingwood, rosewood, etc., have given me that problem. Putting 1-2 coats of dewaxed shellac on first solves the problem and the wipe-on poly will cure over that.
    Sep 2008
    Tacoma, WA
    84
    So even though it was tacky you were able to buff them? Did you sand first, or straight to the buffer?
    4,353
    Quote Originally Posted by Keith Palmer View Post
    I just took it straight to the buffer, ran all through 3 wheels...
    Chuck
    Tellico Plains, TN
    Sep 2008
    Tacoma, WA
    84
    OK, I took a scrap piece of padauk with the poly applied the same as I have on my mills and buffed it. Now I have the grain filled with buffing compound and wax, leaving white spots.
    Is there a way to remove the compound and wax from the pores? Or am I buffing improperly? I know I should have used grain filler, but it is too late now that the poly is on.
    Thanks for all the help!!
  1. New way to do wipe on poly
    By Mark E Smith in forum General Woodworking Q&A
    Last Post: 04-07-2016, 11:41 PM
  2. Minwax Clear Satin Wipe on Poly and Min Wax Sanding Sealer
    By Mike Turner in forum Finishing School
    Last Post: 12-14-2014, 11:18 AM
  3. Box Elder - Follow up Question regarding Wipe on Poly
    Last Post: 02-24-2012, 02:26 PM
  4. Poly Problem
    By Brian Gallagher in forum Finishing School
    Last Post: 07-29-2009, 04:26 PM
  5. wipe on poly
    By Chris Mire in forum Finishing School
    Last Post: 11-30-2008, 03:50 PM
