Results 1 to 8 of 8
Thread: SketchUp Scene Question
    I find that if I add new layers to an existing drawing:
    1. They are always visible
    2. They show up in all the scenes I have created.
    Is there some setting I am missing that would allow me to add layers and not affect scenes already setup?
    My solution has been to make a drawing template with enough layers to start so I won't have to add layers during the drawing process. This seems like a sledge hammer solution since I had to draw on each layer to make it work.
    Keith
    Cedar Park, TX
    320
    I think all you should need to do is unclick the visible for the layer(s) in question in the "Layers" window, then right click the scene tab in question and click "Update".
    Jerry
    Sacramento, CA
    1,367
    if memory serves, layers and scenes are independent of one another. I think Jerry's advice is the only way to go if you're adding layers after you've made your scenes.
    Jason Beam
    Sacramento, CA
    Jason that is how I fix it but with several scenes it becomes quite tedious. I am just asking if there is an faster way.
    Keith
    SE Minnesota
    2,526
    There is a plugin that will add invisible layers. You would then make them visible for the Scenes for which you want them to appear. I'll get and post a link to it shortly.
    SE Minnesota
    2,526
    Try this link.
    Thanks Dave that Ruby script did what I needed. I thought I had just missed something in the use of layers. Seems others wanted hidden layers created.
    Keith
    SE Minnesota
    2,526
    Indeed Keith and you're welcome.
  1. Sketchup Question
    By Les Hoste in forum Designs, Plans and Sketches
    Last Post: 11-24-2011, 03:54 AM
  2. SketchUp Question
    By Pete Simmons in forum Designs, Plans and Sketches
    Last Post: 10-19-2008, 03:27 AM
  3. Maple Bowl w/Scene
    Last Post: 12-12-2007, 08:59 PM
  4. Sketchup Question
    By Gregory Hairston in forum Designs, Plans and Sketches
    Last Post: 03-25-2007, 10:16 PM
  5. Question about Sketchup??
    By Donnie Cherry in forum Designs, Plans and Sketches
    Last Post: 02-09-2007, 02:42 AM
