Results 1 to 3 of 3
Thread: Lathe speed control
    Honolulu, Hawaii
    1,103
    Lathe speed control
    Hi everyone,
    I have a Carbotec 6" variable speed lathe, the little one PSI sells (mine is black, the new ones are red).
    My problem is, The speed controller does not hold any semblance of constant speed while under load. Say like if I am roughing out the inside of a little bowl, the lathe keeps speeding up just after I begin my cut. It will do this no matter where the dial is set or whatever I am turning or even sanding. Without any load it will maintain speed perfectly.
    I am sure this model of lathe has many users in the group and I am wondering if they all experience the same lack of steady speed, or is this something I should look into. Is this something that all small variable speed lathes do? It seems to have plenty of power though, it just gets going faster than I want.
    My Jet mini is not variable and so I don't experience speed changes.
    Other than this speed thing, the Carbotec is a good lathe, and solidly built for its size. I have now given it to a friend to begin learning on and he's happy, but I'm still wondering about it.
    Any help or advice will be appreciated.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Goodland, Kansas
    4,834
    Tony before I got my Jet 1220 I had looked at the Grizzly 1220. It did the same thing as you are describing. When you took cuts it would speeds up. It did this every time we took a fairly decent cut. My friend says that happens with DC motors.
    Bernie W.
    Honolulu, Hawaii
    1,103
    Lathe speed control
    Thanks Bernie.
    I kind of suspected that would be it. I guess it's just "get used to it" kind of thing then. I have had no other complaints on the little machine.
    Aloha, Tony
  1. Anyone have an old PC router with speed control on the fritz???
    By Jim O'Dell in forum Off Topic Discussion
    Last Post: 12-27-2014, 01:53 AM
  2. Craftsman Model 351.217150 Lathe's Variable speed control broke
    By Dimitri Schreiber in forum New Tools
    Last Post: 08-13-2010, 09:42 PM
  3. Speed control for router
    Last Post: 08-16-2008, 03:53 PM
  4. Speed control on G0632
    By bob ostermann in forum General Woodturning Q&A
    Last Post: 03-10-2008, 10:14 PM
  5. General Q about lathe motor control
    By Julio Navarro in forum General Woodturning Q&A
    Last Post: 03-03-2008, 10:04 PM
