Results 1 to 10 of 10
Thread: Does a hole in the top of a bench qualify?
    Toronto, Ontario, CANADA
    2,332
    One of the handiest things in my shop is a hole, that's right a hole.
    About 20 years ago, I built the bench shown below leaving a supported hole in the top.
Name:	Veritas Hold-Down used in sawing of clamp rack -small.JPG
    That hole comes in really handy for lots of things such as cutting patterns with a jig saw. I drilled some inch holes in the bench top for use with Veritas hold-down clamps so that I can more easily clamp work over the hole.
    Cheers, Frank
    15,815
    Neat idea, I put holes in my bench by accident
    I guess you could even put a small trash can under that to collect the chunks and dust
    2,332
    I did that. I built a small rectangular bin out of plywood that fits loosely into the whole and collects stuff that falls from above.
    Cheers, Frank
    Arena, Wisconsin
    231
    Frank,
    Ive admired that hole in your bench since you posted it in another watershed.
    About 25 years ago I built a 4 ft, x 8 ft bench with a 2 ft square hole centered on one half. I used the bench for oxy acetylene cutting and electric welding. I think I will incorporate a narrow hole like you have done in my next bench.
    Good idea.
    Frank Chaffee
    Woodstock, GA
    178
    Frank,
    How often do you have to pull one of your tools out of the box? or do you have a cover for it when not in use? Looks like a good thing, cutting over the edge can be a pain.
    Ken
    2,332
    Ken, I can see why you would think that would be a problem, but the answer is that very seldom have I droipped anything down the hole. It does not have a cover.
    Cheers, Frank
    Frank, that is an ingenious idea! Seems to me that most of the good ones are "why didn't I think of that?" dead simple...
    2,332
    Thanks Rick. Yep it's so simple that it is almost ingenious. Most things like this I steal from someone else but every now and then I come up with something myself.
    Cheers, Frank
    Punta Gorda, Florida
    902
    I remember years ago Andy Griffith doing a comedy routine about buying a new pair of shoes that hurt his foot in one spot and so he just cut a hole in the shoe where it hurt. He said that the hole was the best part of the whole shoe.
    Looks like that you are just a smart as he is. Just cut a hole where it needs to be. Could be the best part of the whole bench.
    2,332
    Good analogy Allen! Thanks, and I think that it is the best part of the bench.
    Cheers, Frank
  1. For those of us that Qualify
    By Charles Hans in forum Off Topic Discussion
    Last Post: 08-23-2014, 12:46 PM
  2. Repurposed bench materials - dedicated sharpening bench
    By Darren Wright in forum Carpentry and Construction
    Last Post: 12-31-2010, 05:25 PM
  3. Drill Press - Drilling large hole over small hole or vise-versa
    Last Post: 12-26-2007, 10:13 AM
  4. This qualify as flat work update
    By Per Swenson in forum Flatwork Project Showcase
    Last Post: 02-04-2007, 04:58 PM
  5. This Qualify as Flatwork?
    Last Post: 01-23-2007, 04:11 AM
