Results 1 to 3 of 3
Thread: 10" Delta Bandsaw - Flat Tire
    Melbourne, FL
    472
    OK - My high quality 10" Delta Bandsaw Model 28-195 is great to resaw small pieces of Playdough (before it dries out) and that is about it. I really only use it to knock wood down to size to fit inmy laser.
    It has been a fine saw for what I do with it.
    Turned it on heard loud crack and ended up with a broken tire on the upper (non-drive wheel). Delta tells me part no longer available.
    So I place belt back on wheel. It must of been a very tight fit or a piece went missing as once wrapped around wheel there is a 3/4 inch gap.
    Thought I would wrap the belt on tight and epoxy just the ends to the wheel. Once that cures I would fill in ,with epoxy, and shape it to fit nice and smooth.
    The belt is made of some kinda very hard plastic so I think the epoxy will fill in very nicely.
    Any ideas???
    5,322
    Check Suffolk Machinery - seller of Timberwolf blades. They have tires for your machine for about $13.00 each.
    Melbourne, FL
    472
    Thanks
    Jim - Thanks. I will check with them Monday.
  1. WTB Riser Block for Delta/Rockwell 14"Bandsaw
    Last Post: 03-06-2014, 06:15 PM
  2. Delta 14" Bandsaw lower bearings.....help needed
    Last Post: 07-29-2012, 04:20 PM
  3. Delta 14" Bandsaw bearings
    Last Post: 04-17-2012, 05:06 AM
  4. 10" Tablesaw Blade, 1/8" kerf, Flat-top Grind
    By jim crockett in forum General Woodworking Q&A
    Last Post: 08-22-2008, 01:39 PM
  5. "New to me" Delta Bandsaw...
    By Greg Cook in forum New Tools
    Last Post: 12-29-2006, 12:59 PM
