Results 1 to 10 of 10
Thread: Davis-Wells update and running
    Palm Springs, Ca
    1,169
    Orignally bought the machine from someone going out of buss that had it sitting in a storage room with a dirt floor. Said he bought the machine as a back up and never got it running and it had been just sitting for years and years in storage. The machine would not run,very dirty,filled with old greese and grim,table frozen,guides broke,thrust bearings shot, riser frozen etc...... I paid $150.00 plus $50.00 for delivery.
    Decided to restore this old machine - needed cleaning,degreesing, rust removal, paint and a few parts reworked,new electrical etc..
    Last post i completed the electrical and it was running well. Parts were sent off for repair and to get new bearings and tires put on.....
    Update from last post
    Well its been awhile since i had any time to spend on restoration of my Davis-Wells bandsaw. But i had the last several days off work and nothing in my way so i worked on it a little each day for the last several days and late today i finally was able to put the guide blocks back on it and put the blade back into it.
    Ill hit the highlights of my experience with the reassmbly, forgive me if i dont know the bandsaw language accurately......LOL
    Davis&Wells in Lynwood,Calif (Dan) did all the machine work (balanced the wheels and put new tires and crowned them, Restored and reworked the original guide blocks at my request,reground the shafts,new bearings).
    Note: My Opinion and decision was not to use Carter guides- They are No where close to the durability or performance of the original guides and at the Lynwood shop they were able to do a few things to the original guide design that helped enhance them-see pics below.
    The Wheels
    Putting the uppper wheel back on took a bit of thought - top one i put the shaft on the ground and tapped the wheel back into place - then reassembled the upper part of the machine.
    Putting the shaft in the lower part of the machine after i put the pully on that goes to the motor was not bad. Placed it on the ground and tapped it down until i got it in alignment with the motor pully (tapping and holding it up and making sure the alignment was correct and tapping until it was in perfect alignment)
    Putting the lower wheel was a bit harder because he had to go back in with the shaft mounted in place. Problem was to put it back on with out putting to much pressure on the shaft and bearings. I called Dan back in Lynwood who explained how i could fasten a 2x4 across the back and over the shaft with clamps and then tap it back on. I did and it worked very well.
    Guides
    Upper guide simply bolts onto the adjustment bar and was no problem
    Lower guide pretty much went on the same way with a spacer that keeps it from hitting into the tilt part of the table.
    Turned it by hand and made all the adjustment to get it to ride the crown (Tilt and Tensioning)
    Then adjusted the upper an lower guide block and thrust bearing seatings. In playing around with it i found the bolt on top is to adjust the thrust bearing - Like i said i dont know much about bandsaws.....LOL
    Placed the saw blade into the machine and tensioned it up and toggled the switch and watched it several times to ensure it was tracking well and that the blade was running in the guides correctly.....all seemed fine after several short trial starts so i flipped the switch and let it just sit and run for awhile...........kinda just stood back and watched it........wife thought i was nuts and wanted to know why i kept watching it...........I told her as odd as it may seem i was just amazed at how the machine was working and thinking imagine how long since its been that this machine was even running.
    Question:::::Now looking for a upper wheel guard like a round sheet metal plate looking thing to complete it .......any thoughts?
    Ohhhhh and wow does thing cut wood.......wish i could show that to...
    Thanks so much for the advice and suggestions everyone has made along the way this has been alot of fun to restore.........Dan
    Attached Thumbnails Attached Thumbnails Angle (450 x 600).jpg   Back (450 x 600).jpg   Bottom Guide (450 x 600).jpg   Front (450 x 600).jpg   Motor (600 x 450).jpg
    Side-1 (450 x 600).jpg   Side-2 (450 x 600).jpg   Side (450 x 600).jpg   Top (600 x 450).jpg   Top Guide (450 x 600).jpg
    Orem, Utah
    935
    Wow - check out the solid wheels! Those blade guides look plenty solid as well.
    It must be quite a feeling to have a hand in a "resurrection" like that. I would have stood and stared too. Well done!
    Quote Originally Posted by Kerry Burton View Post
    Restoration just does not cover it, I agree with Kerry, "Resurrection" is a much better description.
    That saw should serve you faithfully for a very long time to come
    Well done indeed!
    30,014
    Looks like you saved a great machine. Beautiful job. Kudos and congrats.
    Alexandria, Virginia
    1,071
    That looks great Dan, thanks for the update. Looks like you really nailed the color!
    The Heart of Dixie
    4,268
    What more is there to say?
    Custom built boats and Kits
    17,472
    now thats a fine example of thinking green,, safed a old piece of scrap and made it live again
    Palm Springs, Ca
    1,169
    Thank you to all for your comments and advice along the way.....Dan
    Sep 2007
    St. Louis, MO
    583
    That's a sweet saw! Nice job, and the thing will outlast all of us.
    About the upper wheel cover, are you sure it ever had one? The setup you've got was actually pretty common for machines at the time - protect the blade and wheel perimeter - don't worry about the rest of the wheel, especially if it's a solid wheel. See older Craftsman, Walker Turner, or Homecraft saws.
    I'm pretty impressed by Davis Wells turn-a-round time. It sounded like there's one guy in the place with a pile of work backed up behind him. I thought you'd be out of commission for a bit longer.
    Paul Hubbman
    The Heart of Dixie
    4,268
    Yes, what Paul said. Odd or there was never a guard there. The odds of getting hurt are pretty slim I would think with a solid wheel. There is nothing to get a finger in that would do much damage. It would scare the stuffing out you.
    If it were my saw, I would just leave it alone and not stick my finger in there.
  1. Davis Wells Bandsaw Question
    By Dan Mosley in forum Old Iron
    Last Post: 03-02-2009, 07:17 PM
  2. Another day on the Davis-Wells Bandsaw project
    Last Post: 12-01-2008, 04:15 PM
  3. Update Davis-Wells - Paul i got pics to.
    Last Post: 10-30-2008, 02:31 PM
  4. Davis-Wells Bandsaw Color ?
    Last Post: 10-27-2008, 03:47 PM
  5. Trying out my Dad's now my Davis & Wells shaper.
    By Bart Leetch in forum General Woodworking Q&A
    Last Post: 11-12-2007, 10:03 PM
