Results 1 to 3 of 3
Thread: Plywood vs. Veneer (same species)
    new york city burbs
    10,188
    Ive never worked with veneer, and I will be making cabinet doors.
    simple doors, and Im not sure if I should attempt some veneer(glued) over
    something like 1/2 inch MDF, or just buy something like Mahogany 1/4 inch plywood and make it easy,(either way, no worrys about wood movement.)
    Besides being able to get a "nicer" looking grain or pattern, is there any advantage of veneer over a quality ply?(for door panel use only)
    allen,
    unless you are speaking of paperbacked veneer? applying veneer is a whole `nuther skill set that requires some different tools and practice to master, it`s not that dificult but most folks just don`t jump in and slap down some beautifully matched crotch panels their first go.
    if you`re talking about the paper-backed products the just buying 1/4" ply will give you the same look for less money.
    new york city burbs
    10,188
    Ill stick with the ply until someone shows me how to use the stuff.
  1. Patching plywood veneer -- oops. (video)
    By Art Mulder in forum General Woodworking Q&A
    Last Post: 12-20-2014, 01:58 AM
  2. species for children's toys
    By Mark Kosmowski in forum General Woodworking Q&A
    Last Post: 09-22-2013, 06:43 AM
  3. 175 different species
    By Mike Stafford in forum Lathe Project Showcase
    Last Post: 05-19-2011, 11:01 AM
  4. A new wood species for me.
    Last Post: 10-31-2010, 03:09 PM
  5. Vase, species uncertain
    By Mark Pruitt in forum Lathe Project Showcase
    Last Post: 09-04-2008, 01:16 PM
