Results 1 to 4 of 4
Thread: Back with Questions
    Back with Questions
    Just getting back following Introductions last month and have some questions I thought I may get some help or comments?
    Setting up Mitre Station:
    My build-out is coming along well for the M/Station. Benchtop is dbl-layered 3/4" Melamie with Drop-down for Dewalt 705 12" which is boted down with
    (4) 1/2" Wing bolts.
    I'm planning to dado T-Track to allow Fence to slide and it can also accomodate my Router Fence. Looking at "T-Track", although it looks like Hartsville also sells some nice Track, as well as Kreg. The drop-down that houses my M/Saw is built so I can slide it out on a seperate piece of Melamie board. This allows me to pull it out and extend my Cutting length range should I be working with more than 8"ft boards. Have to open the Shop door into Hallway.
    The way I have designed this station will allow me to use the same space for a Router station. If I pull the M/Saw section completely out, I can than insert a seperate Boxed type insert that I'm assembling that will have my Router plate with Router mounted below. The center portion of the M/Station is an open Cabinet which will house my Shop-Vac and Router accessories.
    In trying to contain costs but get good quality I am looking at the following equipment and wanted to get a general consensus before purchasing:
    1.) I was planning to use Melamie (either 1/2 or 3/4") for the M/Saw fence. Will the T-Track mount OK to this design and should I Dbl-up with Hard-wood for Facing?
    2.) If I reinforce the Melamie for a Router Table-top, it is my preferred material to keep the Bench-top, M/Saw area, and Router top uniform?
    3.) What is my best choice of the "Many-Many " Inserts?
    I'm considering Kreg insert + Fence / Hartsville insert + Fence, or the Freud SH-5?
    4.) Although I have (2) Routers, 3/4HP B/Decker and 1 1/2HP Craftsman, I am looking to Dedicate an under table unit using either a SKIL for $85.00 which seems to have decent adjustment range and controls, or Spring for a Hatachi MV-12 as these seem to get excellent Reviews. Probably have to be a Re-Con which sell for $110.00
    Hope to borrow G-Kids Digital and post some shots of progress over the holidays
    FYI: The Mrs is already looking around shop and counting $$$$$$$$$$$$$$$
    Bruce N.
    Thomasville, GA
    5,990
    Bruce,
    I'll try to help on some of your questions.
    1 & 2. Melamine is used for many applications like yours. I chose to use MDF for my shop tables and used a double layer for stability for my router. For added protection, I brushed on two coats of shellac, then finished with two coats of wax.
    3. There are many good inserts -- the choice comes down to your pain threshold on cost vs features. Also, be sure it will work with your choice of router.
    4. I have several routers, but chose the Hitachi M12V for the router table when I built my new shop.
    I know what you mean about the $$$$$ aspect. Fortunately, LOML fully backs anything I want to do with my shop.
    Bill Arnold
    17,470
    another vote for the m12v its work horse and much better than the one your thinkun of using..
    30,002
    And yet another vote for the Hitachi M12-V. It's head and shoulders above the others you mentioned.
  1. Back from Reno...back in the shop
    Last Post: 06-27-2013, 07:40 AM
  2. DC questions again
    By Carol Reed in forum General Woodworking Q&A
    Last Post: 12-24-2010, 03:13 PM
  3. Lakers Go Back-To-Back
    Last Post: 06-19-2010, 12:56 AM
  4. First Pen and some questions
    By Sandy Masquith in forum General Woodturning Q&A
    Last Post: 03-05-2008, 05:12 PM
  5. Wax Questions
    Last Post: 05-25-2007, 03:50 AM
