Results 1 to 10 of 14
Thread: Another 9-drawer dresser (Fraternal Twin) -- Finished!!
    London, Ontario
    3,383
    Just a bit more than a year ago I finished a 9-drawer tall dresser for #1 son.
    The plan, all along, was to make a twin of that dresser for #2 son. I had considered making both at once, as I know that I could save a lot of time on machine setup. But with a modest basement shop, I just didn't think I'd have the space to have two large carcasses on the go at once. I was also concerned about the size of the project just getting me down also.
    In the end, it was a good thing, as I learned a few things with the first dresser which resulted in a change of plans for the 2nd dresser. The biggest change was that I made the dresser about 2 inches narrower. Let's just say that since Baltic Birch comes in 60x60" sheets, designing a drawer box that requires bottom pieces that are 30-1/2" wide just leads to many, many headaches (and wasted wood).
    The other big change was using a vertical panel raising bit for cutting the drawer fronts, rather than a table-slaw sled/jig. That was discussed also in another FWW thread.
    Anyways. At this point I'm basically finished. I'm just going to wait 5 days or so for the finish to cure/harden before putting on the knobs.
ID:	26426 Click image for larger version.
ID:	26428 Click image for larger version.
    It is approximately 56-1/2" tall, by 32" wide, by 17" deep. The top, and rails and stiles are solid cherry. The side panel is maple plywood. The drawer fronts are solid maple. I wasn't that thrilled with the brush-on lacquer with the last dresser, so I uses shellac followed by my old-standby of WB Flecto Varathane on this.
    One interesting tidbit was that the shellac was a leftover rattle-can of shellac from a previous small project. I wondered how well the rattle-can would work,and it worked very well. Heck of a lot easier and quicker, than the subsequent ~3 coats of brushed-on varathane.
    Yes, that is some sapwood there in the back of the top. I built the top way back in the spring -- this was a long project with lots of pauses -- and I honestly can't recall if that was intentional or not. I wouldn't be surprised if it was intentional. It's almost above eye-level, and will likely almost always have stuff on it.
    On the other hand I dug up an old photo of the top when it was being glued up:
    And the sapwood is really hard to see. So it might have just been an accident. Wouldn't be the first time that I got surprised by how some cherry aged on me.
    When it gets moved into the room, I'll take some more photos of the piece beside it's (Fraternal) twin.
    I knew this would be a long project, so every time my 9yr old asked me when his dresser would be finished, I would tell him that he'd have it by Christmwas. Whew, made that deadline under the wire.
    ETA: Scroll down, it's finished now and "installed"
    Jul 2007
    DSM, IA
    5,719
    Beautiful on the second one too! I'm sure he will cherish it for a long while. Well Done Art.
    My Website
    17,472
    hey art if you like ratle can shellac try rattle can laquer.. its great for quick work and no sprayer handy.. looks good on the dresser, how did you like the vertical raised panel bit?
    5,321
    ...Yes, that is some sapwood there in the back of the top. I built the top way back in the spring -- this was a long project with lots of pauses -- and I honestly can't recall if that was intentional or not. I wouldn't be surprised if it was intentional...
    Art, I almost always intentionally use the cherry's sapwood in any project I make. I also do it with air-dried walnut. It's natural, and I really think it gives the pieces more character. But that's just me...
    Constantine, MI
    7,890
    1, 2, 3, 4, .... Yep, all there. Nice job Art!
    www.wrworkshop.com
    London, Ontario
    3,383
    Yeah, nine drawers, and at two knobs each on the big drawers, that adds up to Fourteen knobs. Took a while for my son to understand why $8 knobs were not an option.
    Hey Larry, yeah I should give the rattle can laquer a try as well.
    When I was a kid I used rattle can paint several times and it never, ever, turned out nice. So I was a bit surprised at how well it worked this time. However, now that I'm an adult I actually read and follow the directions, which I suspect helps...
    Thanks, all.
    ...art
    Last edited by Art Mulder; 12-09-2008 at 07:37 PM. Reason: I am a terribul spellar
    Lima, NY
    53
    Nicely done Art. I like the drawer fronts and the natural finish.
    new york city burbs
    10,188
    My bedroom pieces were made for me by a small shop. Very simple, but I chose the maple sides and draw fronts with the cherry trim.(no solid maple, all veneer)
    You have good taste Art!
    12,251
    I can only say Jeff took the words out of my mind or my mouth whichever it is.
    Southeast Pa
    2,019
    Art
    That looks great...
    Garry
  1. Replies: 156
    Last Post: 04-09-2011, 06:53 PM
  2. Mahogany dresser, night stand, solids hardwood and veneered plywood finished!
    Last Post: 04-25-2010, 11:41 PM
  3. Seven drawer dresser
    By Toni Ciuraneta in forum Flatwork Project Showcase
    Last Post: 07-02-2009, 08:04 PM
  4. 9-drawer tall dresser -- FINISHED
    By Art Mulder in forum Designs, Plans and Sketches
    Last Post: 11-01-2007, 02:33 AM
  5. Veritas Twin Screw End Vise Install finished
    By Alex Reid in forum General Woodworking Q&A
    Last Post: 02-06-2007, 03:33 AM
