Results 1 to 7 of 7
Thread: Jointers and Planers
    Could someone point in the right direction for websites, Books, etc that will explain the Basics of the Jointer and Planer? What is their primary use and typical projects that will require using them.
    I have a fair understanding of Planer functions but really vague regarding the Jointer.
    Bruce N.
    Sacramento, CA
    1,367
    Jointer:
    Makes a straight surface where none presently exists. Has nothing to do with thickness. This tool creates the first surface from which all other operations are referenced. It is used as the first step in the milling process.
    Planer:
    Makes a parallel surface to a given reference surface. Has nothing to do with straightness. If your reference surface is straight, the surface the planer creates will be straight as well. If you put in a banana, you'll get a slightly thinner banana out.
    Those are the very basic descriptions. You can get a planer to do some of what a jointer does if you provide workpiece support (sleds, wedges, etc). It's time consuming but possible. These two tools work hand-in-hand when milling rough stock. I use the following method with rough stock:
    1. Cut to rough length for a given workpiece.
    2. Joint one face on the jointer (not edge).
    3. Plane the opposite face with the planer.
    4. Joint one edge on the jointer.
    5. Rip to width and/or plane to width if possible.
    Many folks joint both the face and the edge without going to the planer. I dislike this method because i feel it's limiting. I get both faces flat and parallel so that I will have 4 choices when jointing an edge given the direction of the grain.
    Jason Beam
    Sacramento, CA
    9,077
    Simply put, the jointer creates the flat reference surface that your planer uses to thickness to. Your planer makes the cut surface parallel to the reference surface even if that surface is not flat.
    I'm a Knucklehead! Jason just said that . . .
    Dec 2008
    WI
    72
    Quote Originally Posted by Dave Sweeney View Post
    An excellent book. Check your local library for a copy.
    DKT
    Catalunya
    4,632
    Quote Originally Posted by Jason Beam View Post
    I agree with that, but if you have to take off half of the jointer bed to use the planer thicknesser (as in some jointer/thicknesser machines) and then put it back again to make the edges it is rather time consuming, good planning of the different seasoning steps will help a lot though.
    Best regards,
    Toni
    These guys got you on the right track, but I'd add that if you start with straight well seasoned wood, like Toni said, you are really far ahead. Trying to make flat wood out of twisted warped stuff is like digging a hole in a bucket of water, pretty much a waste of time...........DAMHIKT
  1. Lunchbox planers
    By Roger Pozzi in forum New Tools
    Last Post: 10-29-2015, 02:39 PM
  2. Grizzly planers
    By Tony Maio in forum General Woodworking Q&A
    Last Post: 03-07-2009, 11:18 PM
  3. Re Choice of Jointers
    Last Post: 09-23-2008, 03:35 AM
  4. Bench top planers
    By Thomas Lambrecht in forum New Tools
    Last Post: 03-31-2007, 01:29 AM
  5. Speaking of Jointers....
    By Jeff Horton in forum Old Iron
    Last Post: 12-14-2006, 10:48 AM
