Results 1 to 10 of 13
Thread: how do you clean your spray equipment?
    Southern Louisiana
    947
    i know it's a bad thing but do to lack of time and laziness i just spray a bunch of mineral spirits through the gun when i am done using it for the day.
    so i ask, how are ya'll doin it? what is the best way to clean your gun?
    chris
    ps. i am using an inexpensive CH turbine powered hvlp.
    Floydada, Tx
    1,941
    I spray wb conversion lacquer. For the most part, I remove all the finish from the cup and run warm soapy water thru it, then after that run clean water followed by ms. Once a month I pull it completly apart and clean all parts by soaking them in ms for a few hours followed by a stiff brush.
    Monroe, MI
    470
    Gotta love WB for ease of cleanup. I love just washing the gun at the sink.
    I probably only spray them a few times a year, but for oil-based finishes (usually only paints for me) I use mineral spirits. I dump all my scrap in one can. Then I decant off the solvent after a few days into a can of solvent I use for the first round of cleaning--spraying some through the gun, getting the cup clean etc. Then I use some clean solvent. I finish up with lacquer thinner because it cuts the film thats left behind.
    i use lacquer thinner and only do a tear-down after spraying anything with pigments or if the gun is giving me fits.
    I turn the can upside down, and push the button, and wait until the spray clears........
    Vernon, WI
    230
    Lol now that's pretty funny
    I have two 1 qt. cup guns. One is for clear lacquer only and the other I use for oil based paints. I only clean mine out if they give me a fit or if I am finished spraying and there is hardly any material left in the gun. It usualy needs to be less than a 1/4 cup before I will clean it. Haven't had a problem yet and it saves money on solvents. Catalized is a different story and you should clean your gun up every time you use it.
    Oct 2008
    1,357
    I only squirt clear lacquer through my gun. Like Alen I just leave it in the holder until I need it again. If I've finished up what was in the cup (it's a gravity feed) I'll fill the cup half way with lacquer thinner and drop the nozzle in it and again leave it in the holder. comes in handy if I need a few drops of thinner to clean something.
    Aloha,
    4,552
    I was reading the post kind of in a daze. And then it hit me
    Jay
    Honolulu, Hawaii
    1,103
    With all his other hard work, I guess Stu deserves the easy way out with spraying.
    I tore down any gun right after finishing spraying. Lacquer thinner for solvent and blow dried. Never had a problem with clogged guns because I started with a clean gun each time. I have mostly Binks guns, from detail gun to 2 gallon pressure pots.
    I don't use them much now, but thinking of doing some detail coloring of wood turnings, like Vaughn does.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
  1. Progress of an equipment discussion...
    By Roger Tulk in forum Off Topic Discussion
    Last Post: 03-19-2014, 04:45 PM
  2. Got my equipment yesterday...
    Last Post: 05-13-2011, 02:50 PM
  3. Hollowing equipment question
    By Jonathan Shively in forum General Woodturning Q&A
    Last Post: 11-07-2008, 02:00 PM
  4. Weightligting equipment question
    Last Post: 08-21-2008, 08:49 PM
  5. HVLP equipment.
    By Paul Downes in forum Finishing School
    Last Post: 08-07-2008, 09:24 PM
