Results 1 to 10 of 18
Thread: A drawing table and two chairs for my 4 year old granddaughter
    Toronto, Ontario, CANADA
    2,332
    (part 1 of 2)
    At least once a month, a number (that number being somewhere between 12 and 24) of woodworkers mostly from the eastern portion of the greater Toronto area meet for breakfast or lunch. We originally got to contact each other on the Canadian Woodworking forum. But, meeting in person is even better!
    On the first Saturday in December, a group of us met in Leaside for fish and chips and beer. I was particularly fortunate to be sitting across the table from Don McFarland of Markham. Don told me about a table and chairs that he is making for his grandson and I immediately decided that I want to make something similar for my 4 year old granddaughter Jamie. Here is picture that Don later sent me of his table:
Name:	Chairs and table for Jamie 01 -Inspired by this table built by Don McFarland.jpg
    The table supports a role of drawing paper as well as two strips that are held to the table with magnets and keep the paper in position while someone is drawing.
    Don found plans for children?s chairs on the Lowes web site (http://www.lowescreativeideas.com/id...airs_0507.aspx). I thought the plans were quite good and built a couple of chairs with only very minor modifications. Here is an extract from the chair plan:
Name:	Chairs and table for Jamie 03 -Extract from chair plan.JPG
    Last week I built the table and two chairs. The rest of this thread shows and describes the steps in the project.
    (01) Two of the pieces shown in the photo below form the rear legs and back frame for a chair. They were cut using a jig saw.
Name:	Chairs and table for Jamie 04 -Cutting the back pieces of the chair frame using a jig saw -small.JPG
    (02) Each chair has three back slats and each slat must have a rounded section cut out in order that the back of the chair will fit the contour of its occupant. I made a template, marked each slat using that template, cut each slat on my small bandsaw, then smoothed the cut using a Festool Deltex sander equipped with 40 grit paper.
Name:	Chairs and table for Jamie 05 -Template for rounding chair backs -small.JPG
ID:	26537 Click image for larger version.
Name:	Chairs and table for Jamie 06 -Removing a part of a back slat using small bandsaw -small.JPG
ID:	26538 Click image for larger version.
Name:	Chairs and table for Jamie 07 -Smoothing the rough cut made by the bandsaw with 40 grit paper on.JPG
    I followed this up with 80 and 120 grit paper using my Festool linear sander.
    (03) I tapered the front legs of the chairs and all the legs of the table freehand (but very carefully) on my table saw:
Name:	Chairs and table for Jamie 08 -The leg tapers were cut freehand on the table saw -small.JPG
    (04) The slats were attached to the chair using glued and screwed butt joints. Here is one of the backs:
Name:	Chairs and table for Jamie 09 -Assembled chair back -small.JPG
    (05) Most of the joints on both the chair and table were made using pocket hole screws. Here the holes are being drilled with a Kreg jig:
Name:	Chairs and table for Jamie 10 -Drilling pocket holes -small.JPG
    And here a cross piece is being screwed into place:
Name:	Chairs and table for Jamie 11 -Assembling a chair using pocket holes -small.JPG
    Cheers, Frank
    2,332
    (part 2 of 2)
    (06) A chair seat was cut out of Baltic birch plywood, then the chair was assembled:
Name:	Chairs and table for Jamie 12 -Assembled chair frame -small.JPG
ID:	26528 Click image for larger version.
Name:	Chairs and table for Jamie 13 -Assembled chair -small.JPG
    (07) Here, the table frame is being screwed to the top:
Name:	Chairs and table for Jamie 15 -Screwing the frame to the table top -small.JPG
    (08) I next tested both the chair and table for size and strength:
Name:	Chairs and table for Jamie 17 -Frank testing a chair -small.JPG
    (09)The next steps were to build and install a roller to hold the paper, embed four washers in the table top, build a couple of hold-down bars with embedded magnets, paint the table white, paint one chair red, and paint one chair yellow, and install screw-in rubber feet on all the legs.
Name:	Chairs and table for Jamie 20 -Paper roll on finished table -small.JPG
ID:	26533 Click image for larger version.
Name:	Chairs and table for Jamie 21 -Hold down bar on finished table -small.JPG
ID:	26534 Click image for larger version.
Name:	Chairs and table for Jamie 22 -Finished table and chairs -small.JPG
    Cheers, Frank
    Floydada, Tx
    1,941
    Looks really good. Your grandson should enjoy it if he can get you away from it.
    2,332
    Quote Originally Posted by Al killian View Post
    Thanks, but Jamie is my granddaughter.
    Cheers, Frank
    new york city burbs
    10,184
    Thanx for sharing Frank.
    I actually was a bit suprised in the Lowes toddler table picture, the corners of the table were squared off and not rounded.
    My kids were notorious for bumping into table edges.
    Floydada, Tx
    1,941
    Sorry. My eyes always seem to get me into trouble.
    Very nice work Frank.....typical of what I'd expect from you for your grandchildren
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
    30,002
    Very neat, Frank. I'm sure it'll get a lot of use.
    Gotta say I winced a bit on the picture showing the tapering of the legs. Especially since you have a bandsaw and very good sanders.
    Catalunya
    4,632
    Simply great! as usual Frank.! I'm sure your granddaughter will fill miles of that paper with drawings for her loved grandpa.
    Best regards,
    Toni
    Alexandria, Virginia
    1,071
    Frank, you are the Grandfather every kid should have. Great story, great table and chairs!
  1. Need some ideas for 4 year old granddaughter
    By Jay Caughron in forum Designs, Plans and Sketches
    Last Post: 02-09-2015, 07:37 AM
  2. Adirondack Chairs (and table??)
    By David Agnew in forum Designs, Plans and Sketches
    Last Post: 05-12-2014, 10:54 PM
  3. A Lego table to go with the chairs and drawing table that I made last year
    Last Post: 12-15-2009, 02:37 PM
  4. Kids Table & Chairs
    By randy street in forum Flatwork Project Showcase
    Last Post: 03-01-2009, 11:54 PM
  5. New granddaughter is here! Changing table/dresser delivered!
    By Al Navas in forum Flatwork Project Showcase
    Last Post: 03-20-2007, 08:13 PM
