Results 1 to 10 of 22
Thread: 45 stop cut on the band saw question
    Catalunya
    4,632
    Hi there.
    I have to make four pieces like the one shown in #1 to make the four legs of a dresser I'm planning to make.
    Hence I need to cut those stop cut corners at 45 angle, and I do not have a table saw.
    I figured out a jig like in #2 would help me to make those cuts, I would make one cut on the right side of the saw and the other one on the left side.
    However I have the doubt if the piece will not be supported enough to cut it safely.
    Is there any other way to do it?
    I've thought about inverting the jig so that the piece would point downwards but then I could only make the first cut and then I would need to stick a sheet of plywood that would give me the reference corner to slide on.
    Any suggestion will be greatly appreciated.
    Thanks
    Best regards,
    Toni
    SE Minnesota
    2,526
    Toni,
    Could you make the cut with a router and finish up the end with a chisel?
    I think your jig would work fine if you could clamp the work to it. I would extend the piec the work lays on beyond the blade and cut it off in the first pass. That would make it effectively zero clearance.
    Catalunya
    4,632
    Quote Originally Posted by Dave Richards View Post
    Toni,
    Do you mean using a bit like this? or one similar without the bearing?
    this one is too small for it, do you think it would be better getting a bigger one than using the bandsaw?
    Best regards,
    Toni
    SE Minnesota
    2,526
    Yes. A bit like that would work. It could even have the bearing if you want. You'll need some sort of fence though. Router table or, if hand held, a fence on the base of the router to guide against.
    As far as better, I don't know. With an even feed rate you should get a surface that requires less clean up but if you go too slow there's the potential for burning in spots. If you use the bandsaw you'll need to clean up the saw marks. Not likely to get any burning but you'll have those corners to get into to clean.
    Is there any chance you could glue on pieces of wood to make the stopped bevel?
    Palm Beach Gardens, Florida
    185
    Hi Toni,
    Could you tilt your bandsaw table to the 45 and then just stop at the end for the square piece?
    Regards,
    Bill Antonacchio
    Waterford, MI
    773
    Can you give us a sketch of how these integrate into the dresser? If they're to make a joint with another 45, I'd be leery of the bandsaw method. Even with my MM16 and carbide blade with zero drift I dont know that a BS would give tight enough cuts for joints without following up with a hand plane and shooting board of sorts. The router method might be a bit more exact for joinery, but maybe if we saw how these fit in we might get some other ideas.
    Lake City, Florida
    498
    Toni, If you use the jig on the BS, consider turning it 90 degrees counter clockwise from your pic -- that puts the workpiece on the table and will eliminate the tendency of the blade to pull it downward or try to rotate it as you cut.
    Myself, I would explore the router solution first. I've had very good success using the router in a table for chamfering / rounding over edges.
    Tony
    Tony, BCE '75
    May 2008
    Bellevue, WA
    38
    Router with a straight bit
    I would look at using my router table, with a jib something like you sketched out to hold the work piece at the 45 deg. angle, but use a straight bit. Of course the corner would need to be cleaned up with a chisel. You might consider roughing the cut out on the band saw to keep from having to remove a lot of material with the router.
    Dick
    Catalunya
    4,632
    Hi Guys.
    Many thanks for all the suggestions. The idea of a straight bit on the router fancies me. It would leave an almost perfect finish, and chiseling the corner would not be a problem.
    But those chamfers are about 1.5 inches wide, are there router bits that long?
    Just to help you I include a rough idea of how the web frame is going to be.
    As it is going to be a frame and panel structure I'm planinng to use two different woods one brown for the frame and a light coloured one for the panels.
    The final shape of the legs is not defined yet but I want them portrude from the top that's why I need that final ends without the chamfer.
    Best regards,
    Toni
    My first reaction when I saw your jig was "Don't Do It" and here's why... leverage, the piece is a long way from the support of the table and the saw will want to flip it over, and with leverage adavantage, it will do it. resulting in (at the least) kinking the blade, but before that, you will try to stop the tilt and the blade will get flesh in the process. (and possibly bone) I would feel it is not a safe jig due to its small size and the elevation of the cut above the supporting table.
    Best way I would think would to tilt the table to 45 degrees and construct a jug to slide though the miter guage slot or use the miter guage, to feed it squarely. That way the cut would be at the table surface where it should be and the miter guage or jig will support the piece and create the perfect cut. Hands intact.
  1. Band saw question
    By Chuck Ellis in forum New Tools
    Last Post: 12-20-2015, 06:20 PM
  2. Stop it ! Stop it !
    By Dave Hawksford in forum General Woodturning Q&A
    Last Post: 01-27-2011, 04:46 AM
  3. Saw Stop vs the others
    Last Post: 05-26-2010, 08:26 PM
  4. Band Saw Tire Question
    By Christopher K Hartley in forum Turning Tool Questions and Show & Tell
    Last Post: 12-31-2007, 05:39 PM
