Results 1 to 10 of 19
Thread: Negative Rake Scraper
    Goodland, Kansas
    4,834
    While we are on tools and didn't want to steal Larry's post. How many of you use a negitive rake scraper? I think this is one scraper that you actually ride the bevel and what I have seen is for smoothing hard woods.
    Bernie W.
    564
    I made a negative rake scraper similar to the one used by Cindy Drozda in her box video from a 3/4" square scraper that I was not using anymore. It was too thin at 1/4" for what I wanted in a square scraper and decided to give it a new shot at life as a negative rake scraper.
    I beveled both the top and the bottom into a broadly rounded scraper and then sharpened it with a very steep bevel around 75 degrees. I use it with the sharp bevel up and hone off the burr with a diamond. To my surprise when I used it on end grain it cut fine little ribbons and curls off of some of the hardest woods I use leaving a remarkably smooth surface needind little sanding. I use it primarily for smoothing the concave surfaces of the bottoms of my boxes. It works very well for that.
    If I can find a blank of HSS 1/4" thick and 3/8" wide I would like to make a similar one to use inside of my box lids.
    I may be getting a little older physically but mentally I'm still tarp as a shack.
    Mason Michigan
    455
    I use one that I ordered from, I think Craft Supply. That Stu guy recommend it. It is an Evi Avisera one that they had to order and it took 2 months. I really like it and use it a lot.
    "Small Change got rained on with his own 38"
    Tom Waits
    11,825
    Photos????
    Watcha talking about?
    Aug 2008
    Reno, Nv
    3,632
    Sorry for the hijack Bernie
    I found this link and a few dozen more. Looks like a nice little tool.
    http://www.hiltonhandcraft.com/Artic...%20Scraper.pdf
    30,008
    Thanks for the link, Jim.
    Frank...Google can be your friend.
    Goodland, Kansas
    4,834
    Thanks Jim. I appreciate the link.
    Bernie W.
    hello folks, i use neg rake scrapers allot heres mine
    Goodland, Kansas
    4,834
    Thanks George. Appreciate the pictures. By the way welcome to FWW.
    Bernie W.
    Tellico Plains, Tennessee
    4,351
    What is the advantage of a negative rake scraper??
    Chuck
    Tellico Plains, TN
  1. Negative rake scrapers?
    By Roger Tulk in forum Turning Tool Questions and Show & Tell
    Last Post: 08-02-2015, 11:15 AM
  2. Difference Between a Bowl Scraper and a Shear Scraper
    Last Post: 06-19-2012, 05:02 AM
  3. Negative Rake Scraper
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 11-11-2011, 02:23 PM
  4. about negative rake blades
    Last Post: 06-25-2007, 12:43 PM
