Results 1 to 10 of 16
Thread: face frames
    La Habra Hts. CA
    399
    face frames
    What's everybody using for face frame assembly? Are you guys using a slanted assembly tables with the air clamps or just a flat bench?
    Doug
    Steve Clardy Guest
    Flat bench with deep jaw 10" visegrips. Grips with the swivel pads.
    A C-clamp will also work.
    My bench top overhangs the structure by 3", so I pull the two adjoining pieces over to the overhang, and clamp.
    Puyallup, WA
    330
    If I understand your question correctly, I've switched to using a funky little Krieg jig that consists of a 12" square piece of steel with a one-armed vice clamp that swings around for convenient placement. I much prefer this setup to the old "c" style vice clamp that came with the origninal Krieg jig my dad purchased 10 or so years back.
    Of course (obviously) I don't do this for a living either...
    La Habra Hts. CA
    399
    Quote Originally Posted by Peter Lyon View Post
    Looking for input on how the whole frame is put together. I'm assuming most people are using pocket screw construction. I've seen slanted assembly tables with air clamps to hold in place and keep everything square. Looks like they start at $2,500.
    I would like to hear input if anyone has one of these tables and if not what process is being used to say assemble all the frames for a complete kitchen. My guess would be a flat bench/torsion box and bar/pipe clamps to hold everything square while the pocket screws are installed.
    Doug
    Doug,
    I don't use pocket screws. When I do face frames I use half lap joints, square the pieces on a flat table and just put a single screw in the back to act as a clamp while the glue dries. Fast and easy.
    Puyallup, WA
    330
    Are you doing this (or planning to) commercially? I ask this because if so, then I'm sure its a whole 'nother ballgame. My experience is limited to doing two kitchens and numerous bathroom vaniety's.
    As far as "squareness" goes, any simple flat surface should work just fine. If you've made your cuts square or 90 degrees, the screw will pull the two surfaces together perfectly. The challange, in my experience, is getting the two surfaces "flat". That's what I assumed you were alluding to in your post.
    One of the advantages to pocket screw joinery in my opinion is that if you're unsatisfied with the results, it's easy enough to simply redo it.
    Steve Clardy Guest
    Heres my pocket cutter.
    Trying to find pics of my clamping system. They seemed to have evaporated
    Tokiwadai, Japan
    2,882
    Steve,
    Here are some more....of the cutter.
    http://familywoodworking.org/forums/...0&postcount=16
    Greg
    Are these some of ones you were looking for of the clamping system?
    Steve Clardy Guest
    Quote Originally Posted by Greg Cook View Post
    Steve,
    Greg
    Yes. Those are some older pics I believe I posted on smc.
    My old pc machine, and when I was using a c-clamp instead of vise grips.
    Thanks Greg.
    I've got some updated pics somewhere
    Probably in a folder I haven't found yet
    Hi Doug, I have the Kreg Framing Table, and it works perfectly, it is expensive but if you do alot of face frames, it is the fastest and most accurate way to join face frames, thanks
  1. picture frames
    Last Post: 09-27-2014, 05:19 AM
  2. Owl at 1000 Frames per Second
    Last Post: 10-23-2011, 03:31 AM
  3. A Couple More Frames
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 11-19-2009, 04:21 PM
  4. Face to Face Glue-ups Without Sliding
    Last Post: 11-04-2009, 05:45 PM
  5. Hand planing face frames
    Last Post: 01-19-2009, 03:59 PM
