Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: End Grain cutting boards... in progress
    5,533
    I fired up the kero heater today, and proceeded to cut to length several boards of walnut, Lyptus, Cherry, and Maple. Most of it was 5/4 rough wood, which i dressed up and then glued up into Phase I blanks for end grain cutting boards, about 13" wide by just over 25" long. I ran out of clamps or I would have made at least two more blanks. They're in the house 'curing' overnight. When I get home tomorrow after work I'll send them through the planer, get them smooth and then cut them up and glue them up end grain up for the final time. These are my first attempt at the 'Wood Whisperer' style end grain boards, so I'm not sure how big they'll wind up in the end .
    I was impressed with the Lyptus I picked up at Lakeshore Hardwoods, wish it was a bit thicker. The board I got was typical of what he had available, skip planed at about 4/4 or so thick. I hope I'll be able to get 3/4" out of the boards, but only time will tell.
    That's Maple and Lyptus
    and those are maple, lyptus, Walnut and cherry... two blanks
    -Ned
    Good to see the new shop getting some use, Ned.
    I don't know if you're planning to run the next glue-up through the planer (end grain orientation), but if you do, I'd suggest adding sacrificial wood on the leading and trailing edges of the glue-up to prevent tearing up the edge of the cutting board. I typically just use some face grain 2x4 scrap. After it's all planed to thickness, you can trim off the sacrificial piece with the tablesaw.
    5,533
    Vaughn,
    I'll be sure and do that if I think it needs that treatment after the end grain glue up, thanks for the tip!
    -Ned
    Quote Originally Posted by Ned Bulken View Post
    Vaughn,
    If you're real careful with the glue-up, and use cauls to keep things lined up, you should be able to get away with just sanders to flatten them. Sanding end grain (and getting rid of all the scratches) is a bear.
    Are these for gifts or for your own use (or sale)? If they are gifts, you're gonna be a popular guy.
    5,533
    strictly gifts, one to replace the failing and well used board in our kitchen, the rest are for my Mother, Aunt and a couple of friends.
    There's my saw and in the background you can see the walnut pieces in progress. See the new featherboard I picked up earlier this fall? Works very well, and is quick and easy to set.
    -Ned
    5,322
    Ned,
    Gotta ask - I'ver used Lyptus. In fact, I've never even seen it for sale here, so I don't know what it's like, except to have read that it's a eucalyptus hybrid.
    I have used Eucalyptus, when I lived in California, and it had a very distinct odor, and contained an oil with the same odor - very strong; think Hall's cough drops.
    Does lyptus wood have these oils? If so, won't those oils impart a taste to whatever food is cut on it?
    Just curious. Like I said, I really don't know...
    13,361
    Ahhh, I've been out in the garage with a kerosene heater too.
    I'm liking the heater thing, as when I'm sitting at my bench, I find that it keeps my backside nice and warm...
    Been doing 'sort of' wood working, but I'll post a pic of the finished product in a few days, hopefully.
    Be careful Ned. When people find you can do these end grain cutting boards, they tend to remind you that they need them for gifts! My sister just reminded me, so I guess I'll need to be firing up another batch pretty soon.
    Scratches in the end grain are a bear to deal with. I use a drum sander for leveling off the end grain, so I don't really have to worry about tear out. But it doesn't seem to matter how fine I sand it with the drum sander, I still have to go through a full course of sanding with the ROS after, starting with 80 and working up to 220+ to get a finish I like.
    Look forward to seeing the final product!
    Ned,
    Jim, I can't speak for Lyptus wood, but not all of the eucalyptus species have the medicinal smell. The red ironbark eucalyptus I got a couple years ago at my office has a pretty benign scent.
    5,533
    Ned,
    Jim,
    not that I'm any expert, but it acted a lot like Mahagony, no real 'scent' or at least not a heavy one. And as for the oils, I think part of the hybridization and treatment they put it through deals with that. They actually dip all of the logs into a food preservative. (saw a presentation by the wood science lab which originally commercialized it a few years back.)
    -Ned
    5,533
    Brent,
    I'm making these as gifts, so I doubt I'll have that as a 'burden'.
    -Ned
  1. End Grain Cutting Boards
    By Bill Arnold in forum Flatwork Project Showcase
    Last Post: 11-16-2014, 11:11 PM
  2. Evening shop shots... cutting boards in progress
    By Ned Bulken in forum Flatwork Project Showcase
    Last Post: 09-13-2012, 09:04 PM
  3. end grain boards
    By Jiggs Elphison in forum Flatwork Project Showcase
    Last Post: 11-27-2009, 02:59 AM
  4. End Grain Cutting boards with a different Twist
    By Dewayne Baker in forum Flatwork Project Showcase
    Last Post: 09-15-2008, 01:30 AM
  5. End Grain Cutting Boards are Flat Work
    By Mack Cameron in forum Flatwork Project Showcase
    Last Post: 11-19-2007, 06:55 AM
