Results 1 to 5 of 5
Thread: Water based retarder?
    Floydada, Tx
    1,941
    I am doing touch ups for a hotel and brushing a coat of poly on everything to "FRESHEN" up the furniture. Anyway it is really dry in there. The finish is drying as fast as I brush it on. Called Hood finishes and they recommended adding a teaspoon of glycrin(sp) to every quart. It is supposed to slow down the evaperation of the water. Any ever use this method?
    Bellingham
    2,449
    Al, I know that they use glycerin based products as retarders in artist acrylic paint, but have had no first hand experience. Looking forward to what you experience with this.
    Floydada, Tx
    1,941
    I wil let you know tommrow. Had to go home early today due to bad weather around here.
    30,008
    I'm no chemist, but it seems it'd make sense. Glycerin is used as a wetting agent (humectant) in all sorts of things.
    Floydada, Tx
    1,941
    Well, I have tried it several times. Going from a half teaspoon to 2 teaspoons per quart. No real difference. I sm going to call them in the moring andd request a refund or exchange on it. It is odd that the Target wb poly I used in the same building on the same day went on perfect. I brushed it on and it leveled out perfect. The Hood wb poly dried almost intantly and did/would not level out. I guess you get what you pay for.
  1. Can I use oil-based finish over water based stain?
    By Roger Tulk in forum Finishing School
    Last Post: 09-01-2012, 04:24 PM
  2. Oil based stain and water based poly?
    By John Hemenway in forum Finishing School
    Last Post: 02-14-2012, 03:36 AM
  3. Enduro water based finish
    By Rob Keeble in forum Finishing School
    Last Post: 07-23-2011, 05:27 PM
  4. oil based poly over Water based?
    By Dan Thibert in forum General Woodworking Q&A
    Last Post: 05-26-2009, 01:07 PM
  5. Water Based Stains & Gluing
    By Stephen Volner in forum Finishing School
    Last Post: 11-17-2008, 06:31 PM
