Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 51
Thread: Cabinet project
    Oct 2008
    1,357
    Cabinet project
    I've been building some kitchen cabinets for a remodel I'm doing and reached a point where I need a little input from the group. One of the upper cabinets will be in a corner over a shallow base unit by there self. That upper is going to have a wine rack with a shelf above it. The upper cabinet inside dimensions are 29 1/2"Hx31"Wx10 1/2"D. The wine rack is made of a front and rear grid that are identical with an opening of 4"x4" in each square. To properly support a variety of wine bottles, what would you make the depth of the grid? If I place the front grid flush to the front of the shelf (face frame added later) and I put the rear grid all the way to the back of the cabinet, it seems that the bottles could slide forward and fall. I tried setting the rear grid forward about 2" and it seems to carry the bottles better but is this the way it's done? Below is a few photos to peruse (sorry.. forgot the popcorn)
    17 assorted boxes ready for assembly
Name:	IMG_8231 (Small).jpg
    They take up a lot of room...
Name:	IMG_8271 (Small).jpg
Name:	IMG_8270 (Small).jpg
    The wine cabinet is the one on top
Name:	IMG_8273 (Small).jpg
    After some layout and trial and error I got the first grid assembled
Name:	IMG_8275 (Small).jpg
    Cutting out the second grid
Name:	IMG_8276 (Small).jpg
    Had to see if it was even going to work. Just hate working w/o plans
Name:	IMG_8277 (Small).jpg
    It looks like it could hold about 24 bottles of wine. (if I get it anchored good)
Name:	IMG_8279 (Small).jpg
    There is to be a shelf added above the rack. I'm planning on making a grooved frame around each grid to make it a little nicer.
    Aloha,
    Bellingham
    2,449
    That is a nice size shop you appear to have there Royall. I can tell, because despite all the boxes you have built it still appears roomy. It also appears that you have a wee project going on there.
    I can't help you with the wine grid and it does not appear you need any help. Maybe others like Robert Schaubhut can help. Don't hold back on your posting, it appears you have been sandbagging on us. Give us a few details on your construction details. I know I am interested.
    Thomasville, GA
    5,992
    One good option is to make the grid from solid pieces rather than the lattice. That way, any size bottle will be fully supported.
    Bill Arnold
    Inside the Beltway
    2,666
    Royall,
    I think you've got plenty of support. Are the spaces too big? Could you get more bottles in if they were smaller? Also, wouldn't it be good to continue the grid all the way to the top of the box? If it were attached all around, would that give more strength?
    Would it be possible, and worth the effort, to rout some minor detail into each piece, just to dress it up a little?
    The whole project looks great so far! Good work!
    Bill
    Oct 2008
    1,357
    Quote:
    Bill Satko: That is a nice size shop you appear to have there Royall. I can tell, because despite all the boxes you have built it still appears roomy. It also appears that you have a wee project going on there.
    Thanks for the warm fuzzies Bill, the shop is 20x28 and still not set up in an easy use form yet. I need to find out what I'll be using it for mostly and tailor it to that job I think. It wasn't meant to be for making a living from but right now that is what it is. I want to learn how to use the used lathe I bought and make some spinny things
    Quote:
    Bill Arnold: One good option is to make the grid from solid pieces rather than the lattice. That way, any size bottle will be fully supported.
    I was thinking of going with a solid unit like what Robert built. With the easy to follow directions he posted while making his it would have been easier for me to figure out but the customer brought me a magazine with a itty bitty photo and said they wanted something like that The customer gets what they want.
    Quote:
    Bill Lantry: I think you've got plenty of support. Are the spaces too big? Could you get more bottles in if they were smaller? Also, wouldn't it be good to continue the grid all the way to the top of the box? If it were attached all around, would that give more strength?
    I came up with 4" spaces because that is about what was in the photo as it is there is room for just about 24 bottles, more than enough to get me on my lips but I don't want to get it too heavy as I have to mount it to a wall that is made of foam and concrete. It's called Castle Block here and I'm still working on that problem I would have made the grid to the top of the box but the customer wants a shelf like in the photo. If I think of it I'll scan the photo and post it. The grid is made of 3/4" poplar cut to 3/4" wide strips. I'm planning to make a boarder for the grid of 1"x1/2" poplar with a 1/4" groove to wrap each grid to give it a cleaner look than what the mitered ends are right now. As far as strength goes when the upper shelf is in it will be as strong as it would be going to the top
    If I was an artisan I would add some detail but I can just see me screwing things up trying to get too fancy I'd be happy to listen to any suggestion though The other thing I have to consider is all the cabinets are to be painted an off white inside and out Geez it hate painting
    Thanks Bill, Bill, and Bill for all the good words. I'll try to keep the photos coming and will listen to any advise. This is only my 3rd set of kitchen cabinets and my first for money
    Aloha,
    Bellingham
    2,449
    I suppose you have estimated the weight of the wine, but if you have not, I did a little searching and come up with:
    750ml ... 3lbs each
    Champange or Liter ...4lbs each
    Using 750ml bottles that would be 72 llbs for 24. About the same as all the dishes that were in Bill Lantry's kitchen cabinet...maybe a little less.
    Honolulu, Hawaii
    1,103
    Cabinet project
    Royall,
    Looking real nice there my friend. That's a decent project you got going.
    Nice shop too. Needless to say, I am jealous, but we have talked about that already.
    As for the wine rack, I think you have the right idea, and I agree that if the back grid isn't close enough to the front, bottles might slide off. I would make sure there is at lease 2 inches of engagement on the average bottle. As long as the base of the neck cannot slide forward any, that should hold the bottles securely. Some bottles have a straighter, narrower body and could be a problem if they slid out, but bottles like that should be placed on the botton of the rack, IMHO. As long as the bottles can touch the back of the cabinet and the necks rest properly on the front grid, you should be OK.
    As to some decoration on the grid, what would it look like if you used a 1/4" radius roundover bit with a fairly large diameter bearing, so you could not go all the way into each corner, and just did an incomplete roundover in each bottle hole of the grid? You would have a little variation to accent it but not be a complicated job to do. Just my thoughts.
    Oh and as Bill points out, there will be substantial weight with a fully loaded rack. I think you have enough support and it probably won't be full all the time anyway. Can you mount it on french cleats that can be screwed with shields and also glued to the wall? That might give you more support.
    Keep up the good work. I'll be interested in seeing it progress to completion. I am sure your customer will be pleased.
    Be talking to ya again sometime Brah.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Oct 2008
    1,357
    Quote Originally Posted by Bill Satko View Post
    750ml ... 3lbs each
    What, Me plan ahead Didn't even think about checking the weight.
    I'm thinking of using a tile blade in my worm drive and inlaying a couple of pieces of 1x4 into the wall with epoxy or construction adhesive. If I use several screws into the 1x4's hopefully that will take care of the weight. Right/wrong??
    Aloha,
    Thomasville, GA
    5,992
    Quote Originally Posted by Royall Clark View Post
    ... I was thinking of going with a solid unit like what Robert built. With the easy to follow directions he posted while making his it would have been easier for me to figure out but the customer brought me a magazine with a itty bitty photo and said they wanted something like that The customer gets what they want.
    Amen on the customer getting what they want!
    If I ever have a need to build wine rack, I'd follow the design David Marks did on one of his show. Here's what it looks like. A design like this allows any size bottle to be stacked within each cubicle.
    Bill Arnold
    Oct 2008
    1,357
    I was thinking on those lines Bill. An opening large enough for several bottles in each one maybe.
    Tony I like the idea of the 1/4" round over... run it a little deep to get some of the wing profile cut in... might be a good idea. Thanks
    Aloha,
  1. display cabinet project
    Last Post: 06-21-2016, 02:34 AM
  2. kitchen bench and cabinet project
    Last Post: 08-22-2007, 12:04 AM
  3. Project China cabinet.
    By Bart Leetch in forum Designs, Plans and Sketches
    Last Post: 07-01-2007, 04:10 AM
  4. Project China cabinet.
    By Bart Leetch in forum General Woodworking Q&A
    Last Post: 06-30-2007, 09:37 PM
  5. My Kitchen Cabinet Project
    By Ned Bulken in forum Carpentry and Construction
    Last Post: 03-02-2007, 02:57 AM
