Results 1 to 10 of 23
Thread: extra B.Saw table surface?
    17,472
    has anyone you folks got a extra table setup on your band saw? got some 48" 8/4 that needs some scroll cuttin and my table for the saw isnt large enuff to support it well.. and i got a piece i can use for the table but where do you postion it? beypund the cut or in frt or rt side complty.. centered???/ got a pic of yours for me to see or a link that shows one? thanks this doesnt look like a jig saw job to me!!! not even a festool
    Bellingham
    2,449
    What a coincidence. My PBS station decided not to have a fund raiser yesterday and they actually showed a New Yankee Workshop episode. In it, he cut out his table top on his band-saw and was using his shop built auxiliary table. I had seen it before, but I could not help thinking, I need to build one of those. I suggest you check out his website, he probably had an episode on building it.
    P.S. I believe he showed using the setup in the front, but I think you could move it around to the side if you wanted for re-sawing.
    Michigan
    2,436
    When I first glanced at this thread I thought you were asking for extra B.S, which I thought was odd cause I thought you had an adequate amount already.
    .....carry on.
    Oct 2008
    1,357
    Quote Originally Posted by Steve Ash View Post
    .....carry on.
    Aloha,
    Bellingham
    2,449
    Ok, I read your post a little closer and Norm's is really a circle cutting jig for his bandsaw. Personally I think you probable need both an infeed extension and outfeed extension, maybe something along the line of:
    www.woodcentral.com/articles/powertools/articles_828.shtml
    This is an outfeed table, but you could build the same for the infeed. I need to do the same, because I have the same problems. I still want to build a circle cutting jig for the table saw to supplement my router circle cutting jig.
    30,017
    I have an outfeed extension on my bandsaw. I made it for using a sled on the bandsaw
Name:	Bandsaw Outfeed 1 - 800.jpg
ID:	26971 Click image for larger version.
Name:	Bandsaw Outfeed 2 - 800.jpg
    The table attached via this rail. There are a couple threaded knobs that clamp the table onto the saw.
Name:	Back Rail 2 800.jpg
    The fat parts of the legs are sliding covers for the turnbuckles in the legs.
Name:	Leg Turnbuckle Exposed 800.jpg
ID:	26974 Click image for larger version.
Name:	Leg Turnbuckle Detail 800.jpg
    Since the bandsaw is right next to my lathe now, more often than not the outfeed table is used as a nearby flat spot to set things down when I'm turning.
    Bellingham
    2,449
    So what you are telling us, it is REALLY your lathe auxiliary table.
    17,472
    .....carry on.
    Quote Originally Posted by Royall Clark View Post
    ok both of you guys are headed for coal in yur stockings,,yur jist benun mean today yuo would think i gave some of you harasment in the past and vaughn thanks for the support and hook up ideas... my old B.Saw doesnt have any fence system and no holes in the table yet.. but i can put tsome in it..
    30,017
    Quote Originally Posted by Bill Satko View Post
    My whole shop is pretty much the lathe auxiliary table.
    3,134
    Larry
    You can fasten some hardwood strips 1"x1" or 3/4"x3/4" with washers between the wood & the factory table edge to make it stand off because most table edges aren't flat, then drill mounting holes down through the new large top & wood strips to mount the table to. This way you don't have to drill holes through the top of your table top.
    I made a bigger table using Nick Englers instructions & plans. The table fits around the factory table which makes it very difficult to mount & get the two tops level with each other. But the method of mounting is the same as described above & should work great with a table mounted on top of the factory table.
    Attached Thumbnails Attached Thumbnails Band-saws 003.jpg   Band-saw top mounting.jpg
  1. Hardboard play surface
    By Lynda Zahm in forum General Woodworking Q&A
    Last Post: 10-25-2011, 12:04 AM
  2. hard surface router top
    By Julio Navarro in forum Jigs and Fixtures
    Last Post: 05-29-2011, 06:13 AM
  3. Replies: 12
    Last Post: 10-20-2009, 05:29 PM
  4. How to prep jointer surface?
    By Dan Birnbaum in forum General Woodworking Q&A
    Last Post: 02-18-2008, 11:08 PM
  5. Solid Surface Class
    By Mike Henderson in forum Off Topic Discussion
    Last Post: 09-27-2007, 06:06 PM
