Results 1 to 10 of 17
Thread: Working with UHMW
    Working with UHMW
    I just purchased a sheet of UHMW to replace the fence on my router table (the fence was MDF). I would like to hear from other people about their uses and experience of UHMW. Thank You.
    DKT
    Inside the Beltway
    2,666
    Dietrich,
    It's great stuff. Mills nicely, slick as anything. Best use I've found for it: router bit setups. One piece I have is dependably 3/4", good weather or bad. I get the bit height *exactly* where I want it, and run a piece through. Makes for very repeatable setups...
    Bill
    11,832
    I have wondered how those strips are glued to the fence. In my experience you can't glue UHMW no way, no how.
    17,472
    i have it on my router table fence and works well and has held up well.. frank they use t bolts to hold in in place on mine. set up blocks fo rme are the scrap piece's that i made.. use then next time for the same setup.
    11,832
    OK, I have seen thin strips that come in rolls. Wonder about sticking that.
    17,472
    frank that stuff has adhesive already on it and it holds as well!!!
    I use the wide UHMW "tape". It is very consistent in thickness and the results will be directly proportional to the flatness of the surface you mount it to. . . . ohhhh; big words
    Alexandria, Virginia
    1,071
    I do like the material and use it more for its dielectric properties than for its lack of friction. A search for gluing it to a substrate reveals "some" success with roughing up and heating the surface to be glued and/or using an epoxy like:
    West System Two-Part Epoxy
    Loctite 3030
    or
    3M Scotch-Weld DP-8005
    Bellingham
    2,449
    Frank, what applications are you using it for its insulation (electric conductivity) properties?
    No glue, it just bolts to a metal fence. My table is a Bosch, I wouldn't recommend buying one though.
    DKT
  1. UHMW Tape - Ever use it?
    Last Post: 11-16-2011, 03:04 AM
  2. UHMW snowman
    By Frank Fusco in forum Lathe Project Showcase
    Last Post: 12-24-2008, 01:20 PM
  3. UHMW - Two for One
    Last Post: 09-05-2008, 09:33 PM
  4. UHMW question
    Last Post: 03-23-2008, 09:24 PM
  5. ? about UHMW
    Last Post: 05-29-2007, 01:19 PM
