Results 1 to 6 of 6
Thread: Steel City Drill Press Mobility
    Hi everyone
    I need to be able to move my new drill press around the crowded shop, err garage.
    Thanks for all the suggestions on rolling stands. Here's what I ended up with.
    I had a rolling base for a DJ20 that I was going to buy last year from Amazon. They shipped the base and then delayed forever on sending the jointer. When I cancelled the jointer they wouldn't let me return the base.
    So, I was going to give it away here but then thought that will a bit of cutting I could have a good mobile base.
    I went to a machine shop and had them cut a section out of the two sides.
    Then I milled out some maple so that it fit TIGHTLY into the hollow tube sides.
    I reassembled the frame, forcing the two sides over the wood using big parallel clamps.
    Then I bolted on a base laminated from two 3/4 inch pieces of ply and bolted the unit on top.
    So far, so good, it rolls easily and isn't tippy when I'm moving it and when I drop the wheel down it is rock solid.
    Probably isn't a cost effective way to go, but since I had the base and was going to give it away anyway this approach seemed to work
    Jay
    Looks like a great solution. Glad it worked out
    Steve Clardy Guest
    Excellent solution Jay
    Punta Gorda, Florida
    902
    Good job Jay! Nothing better than to be able to use something that you already have. Sounds like good economics to me.
    London, Ontario
    3,383
    Jay... isn't it a bit awkward to reach around to the back to push down on the lift/wheel ?? It would be in my shop, since my DP is pushed into a corner or against the wall.
    Looks good though, can't hardly see the seam.
    Art
    Yeah I thought about aligning the DP so the wheel was in the front, but decided that I was going to be hitting it all the time with my feet when I was using the DP so I decided to put it on the back. So far I haven't had any trouble, it is jammed up against a wall, I just push down with my foot and then pull the bad boy out.
    Jay
  1. FS: Steel City 17" Drill Press - $350 - SE Michigan
    By Matt Meiser in forum Old Ads
    Last Post: 12-31-2008, 07:24 PM
  2. Steel City new Tops
    By Aaron Beaver in forum New Tools
    Last Post: 09-03-2007, 08:58 PM
  3. Steel City Drill Press
    By Jim McDonald in forum New Tools
    Last Post: 02-21-2007, 08:54 AM
  4. Steel City Toolworks 17" Drill Press
    By Jay Lock in forum New Tools
    Last Post: 02-17-2007, 11:26 PM
  5. Steel City Drill Press II
    By Greg Cook in forum New Tools
    Last Post: 02-03-2007, 08:31 AM
