Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: outfeed table miter slots
  1. #11
    Sep 2007
    Bloomington MN USA
    268
    Out feed table
    Wow.... After seeing some of the set-ups for out feed tables I am very envious. My shop is to small for an out feed table so the best I can do is a couple of roller stands. I usually have to move my sheet stock onto a webbed table made of 1x2s and supported by saw horses (3) I use a Redline 105" aluminum edge that conects to my skill-saw and follows a track. A lot of work but it is acurate and I can do it myself. Sure wish I had the room for an outfeed table. But if you have carbide dato blades they will do an very good job on cutting the slots. A very small amount of your miter gauge goes into the slots anyway.
    If you make a mistake it was part of the original plan!
  2. #12
    Oct 2008
    1,240
    Ron I've got an out feed table but still use about the same set up as you for breaking down sheet goods. (2x4's as grid screwed to 2 plastic saw horses)You just have a better straight edge than I do. I find it easier than wrestling a full sheet of 3/4 ply around the saw. Just getting too old I guess
    Aloha,
