Results 1 to 10 of 23
Thread: reinforced miter joints
    Sep 2007
    Central (upstate) NY
    1,457
    I'm adding some purpleheart to slots cut into a miter joint. I ripped the slots on my RAS (I'll post pics of the setup on Boxing Day - it is quite entertaining) and am getting ready to cut the purpleheart inserts. I am looking for input as to the best grain orientation of the purpleheart. The exposed section will be the diagonal to the grain, but I do not know if it is better for the flat part hidden inside the joint to be with grain (this is what I would do left to my own devices for a little extra strength even though the purpleheart is primarily decorative) or if that hidden span should be cross grain.
    The project is a jewelry box about 6" by 8" by 3" tall (maybe closer to 5" with top and bottom attached).
    I hope my wording is understandable. Happy holidays to everyone!
    Sep 2007
    1,457
    Took some pictures.
    Here is the setup I used on my RAS to cut the spline slots. (Why couldn't I think of the word "spline" last night for my first post?? ) I wanted to use a climb cut for quality and I would have needed the work piece considerably more forward to have the blade fully behind the workpiece to do an anti-climb cut. As it was, I needed to put a spacer piece between the workpiece and the RAS fence in order for the rear of the cut to be fully cut through (for the spline to be flat across and not have an unfinished cut "blade curve" at the rear.
    Doesn't that 12" Delta FTG rip blade look scary without the guard? The blade is made by Leitz and was stolen from their excess tool department for $10 plus $5 for the professional bushing iirc (the blade, like almost all 12" stock blades had 1" bore but my saw, a Delta 33-890 has 5/8" arbor). I had to make this cut without the guard, so I thought out ahead of time how I could possibly lose an arm with this operation before proceeding. I spent Far longer waiting for the blade to stop spinning between cuts than the actual cutting or even measuring / setup.
    My original post is to determine which orientation of the purpleheart is best. Please feel free to let me know if there are special words to describe these two possibilities.
    This is what I mean by cross grain hidden:
    And this is what I mean by with grain hidden:
    Thanks!
    Nov 2007
    Muskegon,Mi.
    111
    Mark That J-Box looks it's comming right along ,and the miter cuts look good.
    I like the way the spline cut looks very well done. The rip blade looks scary without the guard? Be carefull!!
    SOMEDAY is not a day of the week
    Either way you put it, the grain is going to be at 45 degrees to the grain of the sides, some end grain and some length grain. The direction to choose would be which ever provides the most contrast (if that is what you are looking for) The strength of the spline would be to place it with the long grain spanning across the joint.
    17,475
    mark your nuts!!!!! using that RSaw without guard isnt safe at all.... you could have done that cut witha table saw much safer... as for the oreintation i think either will look god but like Mr simpson the strength is better to have long grain to long grain...
    5,323
    Yow! That setup looks scary!
    The slots look great, though. As for the grain, you want it running across the slot - with the grain running parallel to the back edge of the slot. That way, you'll have end grain showing on both edges, and will add the most strength to the joint.
    Sep 2007
    1,457
    I may make a guard to use if I put the saw in horizontal blade mode in the future. I couldn't use the factory guard this time as it would've been in the way of the cut - something wiggles in my memory about a molder guard accessory available for this saw - might look into that too. What I did do was to turn the key to lockout the power switch (testing it each time by trying to turn on the switch) each time I rotated the work piece. Then I still made sure that my arm wasn't in contact or too near the blade (with the carriage travel knob locked to prevent motion along the carriage) while making the workpiece adjustments.
    Larry, I don't have a tablesaw - feel free to bring me one and build me a bigger shop so I have room for one!
    I thought about doing this on the router table - even bought a slot cutter bit - but didn't think the slot cutter bit was deep enough for what I wanted to do, especially since I would lose depth from what I needed to do to properly align the workpiece for a 45 degree cut. With the tools I have on hand, it seemed like the RAS was the best choice. At any rate, the job got done with no injury, so I'm calling it a success!
    Inside the Beltway
    2,666
    Mark,
    You're a braver man than I am. I would look at that set up and say to myself "no amount of joint strength is worth the risk of that spinning blade!"
    The box looks good, but be careful!
    Bill
    13,464
    Sometimes setting up jigs and such are more fun than building the box itself, even when they are scary looking. At least it looks to be pretty well controlled and limited. Looks like that joint will add a lot of strength to to piece.
    11,833
    I don't have enough knowledge to speak to the strength question.
    From your description, I sounds like you took diligent measures to stay away from that exposed blade. Nonetheless, I wouldn't have done it that way. Yes, it looks scary. Meaning dangerous.
    That box is small enough you could have cut those miters with an ordinary handsaw in, probably, less time than it took to set up that flesh eater.
  1. Chair joints
    Last Post: 09-14-2011, 09:54 PM
  2. Finger joints
    By Bill McQueen in forum General Woodworking Q&A
    Last Post: 02-21-2010, 02:31 AM
  3. Box joints hard ones
    Last Post: 02-02-2010, 05:45 AM
  4. Half-lap joints
    Last Post: 03-20-2008, 03:27 PM
  5. Box Joints Anyone?
    By Dave Richards in forum General Woodworking Q&A
    Last Post: 04-15-2007, 09:56 AM
