great come back frank
Always thinking Larry, always thinking.
Frank,
Those are *very* cool. Nice work!
Bill
Thank you Bill!
Frank the ones I have seen looked like the shank that fit into the wood was pretty short. Me being impatient when it comes to ice cream, I was afraid I would split the handle right off of the scoop!!
Maybe there is more to assembly that I am missing since I haven't put one together. So, you have used one and it feels secure and useable in a fast, ice cream right out of the freezer situation?
Good point Jonathan. The shank isn't very long, maybe 1 1/2". The instructions call for a 3/8" hole which does allow the shank to 'slip' in. Some reviewers said to drill a smaller hole, but, with a good epoxy the little bit of extra space allows for enough glue to hold it in place. I drilled a 3/8" hole and used enough gap filling CA to flood the hole and 'pour' over the top. I wiped up the extra glue after allowing it to seal the end of the handle. The shank is cast with a good rough surface, lots of gluing surface.
I think you have a good mental picture of assembly; drill the hole, fill with glue slip in the scoop. [[Note: slip the ferrule on first, it doesn't fit over the scoop.]]
I was thinking if you tend to like hand-packed ice cream, frozen in the coldest place on Earth, you may run into a problem. In this case you could drill and tap the end of the shank, drill through the end of the handle, screw a long screw into the end of the shank, epoxy the hole, and fit a wooden 'button' on the end of the handle.
I haven't used any of the scoops yet Jonathan. I'm betting the Kingwood and Maple will hold up well, the Myrtle is a 'light' wood, looks nice, but it isn't heavy duty. The B&W Ebony, while nice, just is so so.
well most folks have more patience than that jon but it does look like a great school project and something all could use..
Larry, Jonathan is a saint in my eyes. His patience with the kids at school will last them a lifetime. He is teaching far more than woodworking; he is teaching them they have the capability to produce something of value and that they are part of a larger universe then their home town. My hat is off to Jonathan.
