Results 1 to 10 of 15
Thread: I need a circular saw. Any ideas?
    2,784
    Hi all! Hope you had an enjoyable Christmas holiday.
    I think I'm in the market for a new circular saw. I'd like to keep it around 100.00 or less. Not opposed to going refurbished. I picked up the PC 324 and a Bosch (didn't look at the model number-at Home Depot) and both of them felt good in the hand. I tried the Ridgid, but it has a lever that continually pokes the back of my hand. Anything else anyone would suggest? The Milwaukees are out of my price range, worm drives too and too heavy to boot. The nicer Skills might be ok, but haven't heard anything much about them, other than their worm drives. Need to drop by Lowes tomorrow and see if they have the Hitachi. There is one model with a brake for around 110.00. Makita didn't feel very good in my hand. Guess I could go look at the B&Ds.... Sorry.
    Seriously, any ideas would be helpful. Any specials you know about, rebates, coupons, etc would also be nice to know. Toolseeker didn't have much. Haven't found any Amazon specials today while poking around. A 25.00 off 150.00 might get me to go a little extra to a saw with a brake. TIA!! Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    The Heart of Dixie
    4,268
    Have not priced in a while but I can say I am extremely well pleased with my DeWalt. Had it probably 7+ years. It is heavy but I expect the newer ones to be lighter. But other than that no complaint.
    One feature I really like is an adjustable shoe. That way if you use a cutting guide and the blade ever gets out of square with the shoe you can adjust it. That was why I tossed a B&D and bought my first good saw. The DeWalt. I learned of the out of square shoe after running a door with it!
    Punta Gorda, Florida
    902
    This is the one that I got and really like it: http://www.amazon.com/Porter-Cable-3...1?ie=UTF8&s=hi
    Earlier in the month you could add another dollar and get $25 off which would make it about $125. Did the Dec deal go away or what? I do not see it now. For a $125 I think that it is unbeatable.
    15,815
    I've got this little Makita
    I've had it forever, sure is not a Festool but try as I might, I've not been able to kill it
    Atlanta, Ga.
    26
    Early morning Jim..
    I'm going to join Allen on this with a PC. I have the old 324 I believe as I see they have host of various #'s now. Not having been in the market since I purchased the PC several years ago, I don't know what one has the other hasn't.
    My old 1950's circa Shopmate is still running and has the best and straightest steel fence I've ever seen. I still use it outside on home projects, but the PC fit the ticket with power, base design and light-weigh for cutting down what full panels I do use. I mainly work with solid wood.
    I purchased a left blade as I'm a right hander, but got it home and placed it on a sheet. I boxed it back up and took it back to Lowe's for exchange for right blade. The theory is good but the feel was wrong for me. After 35 years of wood whacking.. "feel" over-rode theory. ha.. ha...
    Regards...
    john t.. sarge
    I have a Dewalt worm drive and have had it for over 5 years now without a lick of problems. I am pretty hard on mine too as I work exclusively with rough sawn lumber so mine has never seen anything under a one inch board.
    While this is liable to stir the pot so to speak, I must say I accidentally bought my Left Hand Saw and even though I am right handed, would never buy another right handed saw again. Its nice to be able to look at the blade and the line without having the climb on top of the stupid thing to try to see where the thing is cutting. After about three uses, I got used to it and just love it.
    The problem is, well this saw is probably over 100 bucks now and a bit heavy. Still it is built to last and I like that.
    Steve Clardy Guest
    I'm a PC fan.
    Still have the older PC framing saw. Can't seem to kill it
    98
    I'm quite pleased with the Makita. I picked it up a couple years ago for around $120 from Amazon, but I see it's gone up in price. Still a good deal though. Cuts straight as an arrow with no noticeable runout. But you can't go wrong with other quality makes like DeWalt, Bosch, Milwaukee, P-C, etc. Look for one that has ball bearings - not the sleeve bearings found on the cheaper models.
    Cheers,
    Kevin
    Indiana
    224
    Quote Originally Posted by Jim O'Dell View Post
    What is your circular saw usage going to be, would be the first question you should ask?
    If its going to be heavy and very active then I would recommend a $100 saw, If its going to be an occasional use, or for just cutting sheet stock down to size then I recommend a lower end saw.
    Why buy a Porshe if your only going to drive it to the super market.
    2,784
    Doug, I won't use it a whole lot. I've actually been thinking about trying to get by with the wobbling Craftsman for a little while longer, and put the money into finishing the lights for the shop. If I use a long, straight guide for an edge, I think I can make it work. If it doesn't and gets too maddening to break down the OSB, then I might go ahead and spring for one. I have found the PC 324Mag for 65.00 plus 20.00 shipping on E-bay. (reconditioned) Would still want to handle a Hitichi before I bought one. Thanks for all the ideas, guys. I appreciate it. Jim.
    Exclusively Irish!
  1. Circular saw trouble..? FIXED it:)
    Last Post: 05-17-2014, 11:26 PM
  2. need a new circular saw
    By Paul Downes in forum General Woodworking Q&A
    Last Post: 11-28-2013, 01:53 AM
  3. Zero Clearance Circular Saw
    By Darren Wright in forum Jigs and Fixtures
    Last Post: 10-16-2009, 01:18 AM
  4. Worx Circular Saw $36
    By Wes Bischel in forum Hot Deals
    Last Post: 05-02-2008, 12:38 PM
  5. My circular saw is dying
    By Mike Gabbay in forum New Tools
    Last Post: 12-19-2007, 09:39 PM
