Results 1 to 10 of 18
Thread: TPI on delta Midi?
    5,533
    TPI on delta Midi?
    Folks, what's the diameter and threads per inch on the delta midi headstock? I think I have to send back a christmas gift to get one that fits my unit. The gadget I received has 3/4" and iirc correctly that's not going to fit, am I right?
    -Ned
    Bellingham
    2,449
    Ned,
    I got the following on the Delta Midi Lathe LA 200 from the web:
    SPECIFICATIONS
    MOTOR:
    • 1/2 HP, 120V, 1 Phase, 60 hz, 1725 RPM
    SPINDEL SPEEDS:
    • 500, 800, 1250, 1800, 2650, 3700
    CAPACITIES:
    • Swing over bed: 10" (254 mm)
    • Swing over base: 7-1/2" (191 mm)
    • Distance between centers: 14-1/2" (368 mm)
      • With extension: 37" (940 mm)
    • Drive spindle: 1" -8 RH thread
    • Drive spindle through hole: 3/8" (9.5 mm)
    • Head and tailstock taper: #2 MT
    • Tailstock through hole: 3/8" (9.5 mm)
    • Tailstock spindle travel: 1-1/2" (38 mm)
    • Tool rest: 6" (152 mm)
    OVERALL DIMENSIONS:
    • Length: 33-1/4" (845 mm)
    • Width: 11" (279 mm)
    • Height: 17-1/2" (445 mm)
    WEIGHT:
    • 85 lbs (39 kg)
    Alexandria, Virginia
    1,071
    Same as the Jet Mini, as Bill said 1" - 8 TPI.
    5,533
    drat. oh well. guess the box goes back to lee valley...
    nova midi chuck 3/4". *sigh* oh well. have to wait for it to show up again.
    -Ned
    1,071
    Ned, did you check for an adapter?
    Click on the link:
    NOVA CHUCK INSERT/ADAPTORS
    Take a look at insert "D" or "T"
    I think Woodcraft sells them.
    11,828
    Ditto Frank T. Get an adapter. Check out PSI and/or Amazon which sells the PSI cheaper than PSI even though they aren't expensive to start with. Follow that? And, I haven't even started on the egg nog yet.
    1,071
    After I posted Frank I checked the Lee Valley site:
    58B03.15 // 3/4" x 16 tpi // $85.70
    58B03.16 // 1" x 8 tpi // $85.70
    Jan 2008
    Stow, OH
    151
    The Nova Midi Chuck is direct threaded. The Nova G3 and up use an insert that allows you to change spindle size.
    Don't keep the 3/4" X 16 chuck. The standard for mini lathe has gone to 1" X 8 already. There is little chance that you will go back to the smaller size.
    If lathe upgrade is in your future, you should look at the G3.
    This chart shows the ranges of different Nova chucks.
    http://www.teknatool.com/products/Chuck_Accessories/Jaw_Sets/downloads/Min-Max%20Ranges%20Jaw%20Table%20(inch)Sep06.pdf
    Gordon
    11,828
    Quote Originally Posted by Frank Townend View Post
    Ye trying to give me a stroke?
    I like the $15.00 to $20.00 priced ones much more better.
    11,828
    Ned, what do you actually need? I know the female for the lathe spindle needs to be 1"X8tpi. What does the male side need to be. I might be able to help. Gotta box full of 'stuff' here that might have just what ye need.
  1. Delta 10" midi lathe motor
    By Billy Burt in forum Turning Tool Questions and Show & Tell
    Last Post: 10-23-2012, 03:24 AM
  2. Delta LA200 midi lathe
    Last Post: 10-19-2012, 12:58 AM
  3. Delta 46-460 Variable Speed Midi Lathe
    By Bart Leetch in forum General Woodturning Q&A
    Last Post: 03-05-2010, 05:18 AM
  4. Delta Midi lathe for sale
    By Dale Johnson in forum Old Ads
    Last Post: 03-07-2008, 08:52 PM
  5. Delta Midi Lathe
    By Billy Burt in forum Hot Deals
    Last Post: 03-06-2007, 04:03 PM
