Results 1 to 10 of 17
Thread: Day off and Tennon Problems
    Palm Springs, Ca
    1,169
    Well i got called off work today .....what a shame now ill just have to stay home and turn wood and work in the garage......LOL. Anyway i have an ongoing problem. When i turn my bowls the tennon breaks off very frequently. I have pictures at the bottom to show. The Tennon is about 7/8 in depth and fits into my spigot jaws on my chuck - i hollowed this one by leaving a tennon in the middle of the bowl and hollowed down to the depth i wanted. Then turned the tennon out of it....then with the scrapper showen i started to take shear cuts off the inside (freshly sharpened) and after in a short time the tennon broke off.........luckily i was on my last few cuts so ill be able to hot glue the pc back on and finish sand it.....
    Wondering what others think about why this keep happening or what i can do to make it more secure...........
    Im thinking that because its green wood (hemlock) that it probably stressed cracked when i was hollowing and didnt come apart because i have the tailstock up tight into the interior tennon i left on. Then after removal and still being green....and being far off the rest and deep hollowing it just cant take the stress even in light cuts..........
    Thoughts ?? thanks Dan
    Attached Thumbnails Attached Thumbnails Scrapper (600 x 450).jpg   Chuck (600 x 450).jpg   Tennon1 (600 x 450).jpg   Tennon2 (600 x 450).jpg   Tennon3 (600 x 450).jpg
    Hardinsburg, KY
    277
    Dan, your tenon is too long. It should not bottom out on the bottom of your chuck. In fact, the top of the chuck jaws should register against the bottom of the bowl. Try it and see if it doesn't work better for you.
    Jul 2007
    Des Moines, IA
    854
    Dan, I agree with Doug, the tenon is too long. Also if the tenon is about the size of the smallest opening of the chuck jaws, the jaws will grip better.
    Good tip.
    That is a good tip for us beginer turners. Thanks.
    Joe Penney
    Nov 2008
    Tampa & NC
    432
    day off tennon problems
    Another thing that wasn't mentioned is that even though you are making a small bottom on your piece ,you don't have to have such a small tennon.You can do as allready said,but have a bigger tennon which will give you more wood for strength,then when you part it off you should be about an inch or so away from the tennon and can make the bottom as small as you like and that should end your troubles.
    Goodland, Kansas
    4,834
    I agree the others. Make your tenon about 5/8" shorter and about a 1/2" larger in diameter. Your tenon is to long and way to small in diameter.
    Bernie W.
    hello, i prefer not to use tenon's for this type of work, i always use faceplates and create a waste block and part of above this.
    if you do ues a tenon you can strengthen it by using a couple of drops of CA or make them larger as has already been mentioned-but ideally avoid them.
    Alexandria, Virginia
    1,071
    Thank you George.
    hello folks just to clarify any confusion i may have caused this is how i work to avoid snapping tenons.
    this is a piece of spalted beech 14" long by about 7" wide
    i start between centres
    i cut one end slightly concave for the faceplate
    i then mount my faceplate this one is 6" straight into end grain using sheet metal pan head self tapping screws about 1 3/4" long
    i wont bore you with the rest of these wip pic's and complete hijack this thread so we will skip along to the waste block bit
    in this pic the vase is complete except for sanding and you can see to the left is my waste block( but not always waste!!)
    sanded and oiled
    waste block shaped into a bowl
    i then used a 3"wide by 1/4" deep dovetail tenon to hollow it out and finally got rid of that tenon using a vacum chuck
    the days efforts
    a 3" tenon may strike some of you as excessive for such a samll bowl but splated beech isnt very strong and as i've already mentioned i prefer to have a large tenon if i'm going to use them. I do not know of any chuck jaws which would have given me such a strong hold on this vase- plus it doesnt help matters that i'm also clumsy and heavy handed so i need it to be strong
    hope this helped
    george
    p.s i have quite a few wip pictures of various projects if you would like to see them???
    1,071
    Quote Originally Posted by George Watkins View Post
    Yes please George. The nice thing about sharing is the ability of turners at all skill levels to interact, share, and gain knowledge.
  1. Snap Tennon
    Last Post: 06-05-2010, 04:23 AM
  2. Reversing and Tennon Question
    Last Post: 08-06-2009, 10:36 PM
  3. Tennon Question again
    Last Post: 02-09-2009, 02:18 AM
  4. Tennon problem - New jaws question
    Last Post: 01-08-2009, 10:32 PM
  5. Dovetail Mortice & Tennon
    Last Post: 07-07-2008, 01:14 AM
